Old August 11, 2012, 01:39 PM
Default Harddrive Rubber Enclousre
Hey all. I want to mount my HHD in my 5.25 inch drive bay area, but I don't have any converter rails or hot swap bays.
Would I have to worry about heat and viberation if I put my Harddrive in one of these rubber enclousers and just set it on the bottom of the 5.25in drive bay area?
Old August 11, 2012, 03:56 PM
Adzsask's Avatar
I just cheap out and use rubber washers, works great.
Old August 11, 2012, 04:49 PM
Looks like the HDD will overheat being in case in rubber like that, or at least that's my opinion of it.
Old August 11, 2012, 05:17 PM
ZZLEE's Avatar
Drive converter hot swap
Canada Computers | Cases | SilverStone CFP52B 5.25" to 3.5" bay converter with hot-swappable function
EDIT : this EverCool Armor HD-AR-BK 5.25in Bay Coverter to 3x3.5in HDD/4x2.5in HDD | eBay
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
!HELP! harddrive issue HipOrc Storage 8 August 8, 2012 09:01 PM
rubber tape thing on backplate of h50 severity Water Cooling 6 April 7, 2011 10:10 PM
Mouse Feet Rubber Dealios headsh0t Peripherals 5 August 22, 2010 09:47 AM
[WTB] cheap ide harddrive flightsimnerd Buy/Sell & Trade 2 January 23, 2010 12:26 PM
Where can I buy some rubber strips for anti-vibration inside pc? appplejack Peripherals 5 January 17, 2009 05:23 AM
