Old July 7, 2012, 03:14 PM
Exclamation need help with hhd and ssd
i need you guy that recomendate the best quality hdd and ssd
that will be good and balanced with
i7 3770k
sabertooh z77
16gb corsair vageance
what do you think about SAMSUNG Spinpoint F3 1tb and samsung 830 128gb?
Old July 7, 2012, 04:13 PM
The OCZ Agility 3 Drives have good reviews and can be fairly cheap at NCIX. I own 2 of them and love the hell out of them. I use one for my HTPC and the other for my games on my gaming pc. Very quick and reliable. Of course there are higher quality ones out there but for the price they are right on.
Old July 7, 2012, 05:04 PM
Overclocking.ca's Avatar
Personally I have had bad luck with the Samsung HDD. I would stick with WD Green or Seagate.
As for the SSD, the Samsung 830 is a good drive. What is your budget?
The OCZ Vertex 4 is a great drive from what I have read.
Old July 7, 2012, 06:29 PM
well i can spend max on ssd 150$
Old July 8, 2012, 12:00 AM
Stosh's Avatar
Is this a gaming build? If so, you might want to think about dropping down to the i5 line, simply because multi threading won't help gaming.
Then take the extra money and put it into a better drive.
Old July 8, 2012, 12:25 AM
dandelioneater's Avatar
Yeah, if this is a gaming build, then drop down to a 3570k and put the 100 bucks you save into a good ssd. Any of these are great. intel probably offers the best performance, best value would be the ocz. crucial is very robust with all around performance/price. I have a vertex 3 and it is a very good little drive.
Crucial m4 256gb
Intel 520 Series 180GB
OCZ Vertex 3 240GB
