Old May 17, 2012, 03:20 PM
Default SSD caching on z68
Hi all,
I have an ASUS P8Z68-V mobo, a 64 GB Crucial SSD, and a 1 TB [COLOR=blue !important][COLOR=blue !important]HDD[/COLOR][/COLOR]. I'm trying to set up the 64 GB SSD as a cache for the 1 TB HDD. I have succesfully installed all of the drivers and the Intel SRT software. Everything works just fine... I click on Accelerate and it lets me set up the 64 GB SDD as a cache for the 1 [COLOR=blue !important][COLOR=blue !important]TB[/COLOR][/COLOR] HDD (I used Enhanced mode). The Intel SRT software shows that SSD caching has been successfully set up, but as soon as I restart the computer it will not boot into Windows and won't even recognize the 1 TB HDD. It says something to the effect of "insert boot media and select proper boot device". What is going on here? I can't really find any helpful posts online and I'm banging my head against a wall, please help!
Old May 17, 2012, 03:21 PM
SugarJ's Avatar
Make sure the boot selection in bios is set to your HDD and not your SSD.
Old May 17, 2012, 03:28 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Yeah your HD order sometimes gets screwed up when you set up caching. Check that HD is set as the boot drive.
Old May 17, 2012, 04:05 PM
It's set to boot off of the HDD that has windows installed, but it says "reboot and select proper boot device"
Old June 19, 2012, 04:17 PM
MARSTG's Avatar
also make sure that HDD is the first in the HDD group. Did you solve it in the meantime?
X58 and caching? Dzzope Storage 5 December 30, 2011 02:44 PM
SSD Caching Setup Issue Zelinn Storage 0 December 28, 2011 02:44 PM
Linus, SRT-Caching r2yneth CPU's and Motherboards 4 December 23, 2011 04:15 PM
Intel SRT-Caching Question r2yneth Storage 1 December 7, 2011 10:37 PM
RST Caching Config Question Lord Babaghan Storage 5 June 24, 2011 10:50 AM
