Old May 7, 2012, 06:28 PM
Default Raid 0 SSD on Crosshair V?
Hello!
I was wondering if anyone had any luck/trouble setting up a raid 0 array on this mobo. I plan to use 2 intel SSD in the future, sata3 , probably 128 gigs.
Thanks!
Old May 7, 2012, 07:22 PM
CMetaphor's Avatar
Quadfather
I don't see a problem. Im using 4x older C300 SSDs in Raid 0 on an older Crosshair IV formula without issue. Go for it
Old May 7, 2012, 08:23 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Depends on the Intel drive you choose. If you go for a 520 or 3 series...you will be in for more hassles than if you go for a Crucial M4 or Intel 510. Like Cmets setup the M4 and 510 drives use Marvel and not SandForce (albeit a newer faster version compared to the C300s).
IF you DO use SandForce drives....idle time....LOTS of idle time will be the key to long term happiness...as they will get into degraded states FASTER than Marvel based drives...and stay in such a state LONGER.
IMHO Raid'ing SSDs only starts to pay for itself when you hit 3 or 4 of them. Two...its just not worth it (usually...always exceptions to the rule).
YMMV
Old May 7, 2012, 09:10 PM
I'm sorry I am very ignorant on this subject. I understand the difference between the controllers, and I will take note of it.
However, I do not understand how 4 drives will give me better performance than 2 in raid 0. I thought 2 SSD in raid 0 basically doubles the read and write rates.
I just want my apps to load ASAP, I probably won't be doing massive uploads/downloads off the SSD, just windows and my games.
Thanks for the comments, you guys know so much!
Old May 8, 2012, 03:11 PM
Soullessone21's Avatar
My main rig is that board with 2 OCZ III in raid 0 and it works flawlessly
if you need help with anything during setup just PM me :)
Current Build:http://www.hardwarecanucks.com/forum...cube-gods.html
Always up for a Beer in Calgary or Area
“Two possibilities exist: either we are alone in the Universe or we are not. Both are equally terrifying.”
[WTB] Looking for some "Edgy" processors! 3770K & 3930K And MORE! Slaughter Buy/Sell & Trade 13 May 10, 2013 04:07 PM
Crosshair V vs Crosshair V Thunderbolt Masteroderus New Builds 6 January 26, 2012 09:23 AM
CROSSHAIR V HELP :) metalcore CPU's and Motherboards 6 June 28, 2011 10:26 AM
Crosshair III or IV? Keltron 3030 CPU's and Motherboards 2 April 16, 2010 11:33 AM
ESata dual raid enclosure = poor man's hardware raid? sswilson Storage 10 May 6, 2008 09:58 AM
