Old May 1, 2012, 01:36 AM
Post WD Velociraptor 160GB... solved.. shanks ^D^
Hi there!!!
I am very very interested in getting a faster harddrive for my current build, however, I am a little confused by the description of this HDD on Ebay. The Harddrive is a WD Velociraptor 160GB and I want to know if it is a SATA 3 drive and if so, can I use it with a SATA 2 header on the motherboard. please help me!!!!! :d
here is the model number: WD1600HLFS
★★ WD VelociRaptor 10000 RPM 3.5" 160GB SATA HDD ★ Western Digital WD160HLFS | eBay
ps: I am in Australia...so yeah :D
pps: Sorry if someone has already asked this, I'm not good at finding things in Forums.. :/
Old May 1, 2012, 03:56 AM
Amarthfea's Avatar
the ebay description isn't very good. but it is a sata 2 @ 3 gb/s
the drive isn't bad for an upgrade, but if your looking for speed an ssd is really the way to go since your not looking for a huge amount of space, the price may not be all that bad.
~Elysium, I behold your beauty...
Old May 1, 2012, 05:00 AM
Dzzope's Avatar
personally I wouldn't touch a second-hand drive.. you don't know if there is any issues at all or how much use it's had.
get yourself a cheap SSD, the WD isn't that fast compared to many other HDD's and not a touch on even the cheapest of ssd's
Old May 1, 2012, 07:22 AM
Thanks for the quick response guys :D
I'm going to go with the Velociraptor mainly because I need the 100gb + of space for my video files (I do a lot of Visual FX work) and at the same price point I would only be able to get a 32gb ssd. I will most definitely upgrade to an ssd in the future when I have the budget for it.
again, thanks heaps for the advice :D
Old May 1, 2012, 07:39 AM
second hand drives from EBAY... BAD idea.
Old May 1, 2012, 09:14 AM
WhippWhapp's Avatar
Get a Momentus XT Hybrid.
I rub and whack and choke and stroke!
Old May 1, 2012, 12:53 PM
Dzzope's Avatar
This... get a standard hdd new or a ssd for speed... one or other... I would not use second hand drive unless I knew the owner personally..
[WTB] Urgent !!! Local Toronto - Need 2 -1/2in Barbs !!! Urgent mattlef Buy/Sell & Trade 0 April 3, 2011 04:44 PM
[FS] 2x OEM 160GB WD Velociraptor (WD1600HLFS) - SOLD vohiep84 Buy/Sell & Trade 2 November 8, 2010 06:17 AM
Should I go SSD or A WD Velociraptor norfolk Storage 21 January 15, 2010 03:39 PM
WTB: Laptop Notebook 2.5" Hard Drive SATA 160gb or higher *URGENT* Jamz Buy/Sell & Trade 2 November 19, 2008 07:56 AM
