Old April 30, 2012, 07:21 PM
MacJunky's Avatar
Default Testing out a SCSI card.
This has all the info for the time being:
ST19171WC on Adaptec AHA-1542CP - Pastebin.com
Slow, I know. This is what I get for not using MCA! :P
Need to dig up some more drives to bench and also take some pix. :)
Old April 30, 2012, 08:15 PM
grinder's Avatar
ummm.. you have a system with a ISA bus right?
Old April 30, 2012, 08:53 PM
MacJunky's Avatar
Yes, the SCSI card is in a 16bit ISA slot in my 286 atm. The Seagate ST19171WC is connected with an 80-pin to 50-pin adapter. Unfortunately the two compaq BD0366459B drives I have are not usable with the same adapter. I would need a less-cheapcrap one.
On a side note, I actually no longer have a board with MCA slots but according to a guy I know with an MCA equipped 386SLC system & SCSI card, you can pull 3MB/s to 4MB/s from a 1997ish SCSI drive. Much faster! :P
Old May 2, 2012, 04:44 PM
That particular drive shouldn't have a big problem pushing 10-12mb/sec. And on random I/O, such drive is still very competitive with brand new 7200rpm current generation drives.
The -WC means that it is designed to plug into a SCA backplane that uses single-ended (not differential) 16-bit wide SCSI.
Old Unix Workstation and SCSI drives snoosebum Buy/Sell & Trade 10 June 15, 2009 07:57 AM
Question(s) - SCSI controller card Magnetar Storage 7 April 19, 2009 01:46 AM
scsi drives in my pc. kyle_L Storage 1 March 9, 2009 10:48 PM
SCSI/SAS finally dead? Dizz Storage 13 October 12, 2008 09:15 AM
SATA detected as SCSI in Vista? no_pulse O/S's, Drivers & General Software 2 October 7, 2008 11:52 PM
