Old April 12, 2012, 10:58 PM
Default installing old hard drive
I have a newbish question.....
Is it possible to just plug in my old primary hard drive, running vista, into a sata 2 port in my new windows 7 build? Would it be just like installing a brand new secondary drive?
My main concerns are (1) even though my old drive would not be a boot drive on this PC, it does have lots of programs installed (including Vista), so it may somehow confuse my windows7 install? (2) possibly introducing a virus, worm, trojan etc or it would hurt the performance of my PC somehow?
Would I just be able to delete all the vista files once installed? Does anyone know of a guide if its complicated?
It would be very hard for me to find all my needed files and transfer all of them. Like old resumes, movies, etc. Somehow I get the feeling it would be easier to search for my important files and put them on a USB drive to transfer.
Thanks for the help
Thanks, Gin...my new build:
Support Intel's X79/LGA2011 platform, it is worthy
Intel Core i7-3820 SB-E @4.6Ghz
ASRock X79 Extreme6/GB
16GB Samsung DDR3-1600 30nm MV-3V4G3D/US
Corsair Carbide 400r
Corsair H70 cooler w/2x COUGAR CF-V12HP 120mm fans
EVGA GTX680
Thermaltake toughpower grand 850
Intel 520 180GB SSD
Seagate momentus XT 750 gen2 hybrid
LG BD burner w/ 3D MDisc Lightscribe
Dell UltraSharp U2412M LED 1920x1200 w/IPS
Cerwin-Vega XD3 sound monitors
Windows 7 Pro 64-bit
Old April 13, 2012, 05:15 AM
I've done this in the past except with another "primary" drive in a USB enclosure and a laptop, and it was two Vistas. One issue I found is that there are a lot of folders that are inaccessible (at least without some "persuasion" by answering a LOT of UAC prompts) to the host OS. If you set your documents folders in Vista to be "private", then you won't be able to access them through Windows 7.
[1] You should be OK as long as your BIOS does not try to boot from it.
[2] If there's a virus on the old drive of course it can get over to your new system. Copying the infected files over and booting from it accidentally are two ways that can happen. There should be no change in performance.
Actually the first issue you may have is that your Windows 7 will lock you out of trying to access, not to mention delete important Vista files. You'll need to use either a Linux Live CD or other tool that doesn't care about permissions to delete any of the OS files (C:\Windows, pagefile.sys, etc.), then you'll need to delete the bootloader. If you want to use the hard drive again, it will be a LOT easier to just image the drive (to save all the stuff) and then wipe the master boot record (MBR) of the drive. We can suggest tools if you want to do that.
Alternative:
It sounds like you still have both PCs functional? If they're on a network, just put a network share on your Windows 7 PC and transfer all the files you want over the network from the Vista PC to the Windows 7 PC. I like this option better as you don't run into the file permission issues and since you are working on your old PC's interface, it will be more intuitive to find your old files.
Assuming you didn't do software development or run old programs that store their data in their install directories, copying over the contents C:\Users should get everything from the old computer.
Old April 13, 2012, 05:32 AM
yes my old PC is still fully functional, but not on a network...but thats a great idea. I did't use any old part for new build, not even my monitor. I will network them together for a week or so, and that will give me time to find all the files I need.
Thank for the help, I didnt even think of a network. MYy old PC, I had it so long that All my files are spread out everywhere and my hard drive is totally full. So networking and doing it slowly, remembering as I go seems like the best solution. I can even do it wireless.
EVGA GTX680
Intel 520 180GB SSD
Old April 13, 2012, 08:17 AM
Painbringer71's Avatar
You will be able to grab save files music pictures etc… The system files are still partitioned an not accessible. What I did when I got a ssd boot drive was set windows like new on the ssd. Then I added the old drive as a secondary drive. Then I grabbed my needed files from the old drive transfer them to an external hard drive. Then I formatted the old drive like new and started over. My boot ssd did not have the room to do it. If your new drive has room then you do not need a external hard drive.
Help Installing 2 hard drives on my ASRock board ginman522 Storage 3 April 6, 2012 10:56 PM
Installing a SSD boot drive and keeping pre-existing drive as it was??? Painbringer71 Storage 4 November 22, 2011 03:55 PM
Installing windows on an ubuntu drive magictorch O/S's, Drivers & General Software 13 August 10, 2011 12:38 PM
[WTB] DDR3 SODIMM, 2.5" Hard Drive, Hard Drive Enclosure TopDogZero Buy/Sell & Trade 2 May 20, 2011 04:24 PM
Installing Windows Vista to a SATA3G hard drive Mr. Gruntsworthy Storage 19 October 6, 2008 09:50 PM
