Old March 22, 2012, 12:08 PM
Soullessone21's Avatar
Default RAID HELP PLZ!!!
Can you add a 3rd drive to a raid 0 setup and make it raid 5 or 10 without reinstalling windows?
Plz help thanks
Current Build:http://www.hardwarecanucks.com/forum...cube-gods.html
Always up for a Beer in Calgary or Area
“Two possibilities exist: either we are alone in the Universe or we are not. Both are equally terrifying.”
Old March 22, 2012, 12:15 PM
dandelioneater's Avatar
I am pretty sure that once to set your raid array up and install windows you will not be able to add a third drive withought breaking the array and reinstalling.
Old March 22, 2012, 01:00 PM
Plz help thanks
You can't even do that without redoing the entire array! Welcome to Software RAID.
Old March 22, 2012, 01:05 PM
Perineum's Avatar
depends on the feature of the chipset you are using.
RAID expansion and migration are nice features
RAID expansion allows you to add more drives as you like...
RAID migration allows you to move from one form of RAID to another.
I'm not sure what chipset you're using but if it's an Intel.... Intel® Rapid Storage Technology — Supported RAID migrations
If you're a ICH10R then what you're trying to do lists there as being supported.
Old March 22, 2012, 01:11 PM
customer is using a Asus M4A89GTD Pro/USB3 and has raid 0 and wants to add one more drive any options?
Old March 22, 2012, 02:18 PM
probably not going to be able to do it without hosing the drives
-joe
RAID 5 wesamess Storage 7 September 23, 2011 07:17 PM
Does SATA III in RAID 0 (on non-SSD) out performing SATA II in RAID 0 (on non-SSD)? SmallWhiteDragon Storage 15 July 19, 2011 12:19 AM
SSD-Raid to 1GB\s Just4Testing Storage 6 September 21, 2010 11:19 AM
I have never used\tried raid Shadowmeph Storage 13 February 5, 2010 07:54 AM
ESata dual raid enclosure = poor man's hardware raid? sswilson Storage 10 May 6, 2008 09:58 AM
