Old March 23, 2008, 07:51 PM
open-6's Avatar
Default WD Caviar SE16 WD6400AAKS
I'm considering getting the WD Caviar SE16 WD6400AAKS as an OS drive. Do I need to partition the drive to maintain performance? My preference is to leave it as one drive, but if it affects the OS performance at some point, then I will partition it.
Intel Pentim 4 2.80 GHz
Asus P4C800-E Deluxe
Kingwin KT-424-BK-WM
Antec TRUE430
Corsair TWINX1024-3200LL
ATI Radeon 9600 PRO
Maxtor DiamondMax Plus 9 120 GB
Sound Blaster Audigy 2 Platinum
Pioneer DVR-112D
Plextor PX-W4824TA
Panasonic 1.44 M floppy drive
NEC Multisync LCD1760NX-BK-1
Old March 24, 2008, 04:55 AM
Mr. Cipher's Avatar
I partition for safety. I do a lot of software tweaking that can render my OS unstable if I make a mistake, so rather than reinstall my OS on the whole drive and potentially loose 500gb of data (I have the 500AAKS), I only lose my 5gb OS partition when I re-format/repair.
i7 Red
EVGA X58 Classy | i7 920 D0 | Megahalems w. 1 noctua push| Mushkin Redline | BFG GTX 295 | 2x640 WD Black | Corsair HX1000 | HAF 932 | Asus 26" LCD
C2Q Blue
Gigabyte EP45-UD3p | Q8400 @ 2.66ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 400mhz | BFG 8800GTX OC | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900 | Acer 20" LCD
Intel E1xxx & E2xxx OC Thread
Old March 24, 2008, 06:21 PM
open-6's Avatar
Would partitioning give better performance though or is there no difference?
Antec TRUE430
ATI Radeon 9600 PRO
Pioneer DVR-112D
Plextor PX-W4824TA
Old April 4, 2008, 05:22 PM
Oversized Rooster's Avatar
You won't gain any performance increase if you partition.
Old April 13, 2008, 02:26 PM
Less fragmentation should mean slightly better performance.
Old April 13, 2008, 03:00 PM
Where do you find this drive anyways?
I have been looking all over for it in the recent weeks, but I can't seem to find it anywhere.
Old April 13, 2008, 03:32 PM
biff's Avatar
Canada Computers has them for on sale right now for $123. I just got one of these a couple days ago and am installing OS as I type this.
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
Old April 13, 2008, 03:38 PM
Yes, it gives you better performance.
That is because it lowers the access time for a certain portion of the drive.
Old May 3, 2008, 02:20 AM
MAC's Avatar
MAC MAC is offline
Associate Review Editor
It is sure taking NCIX/DC a while to stock this little gem....I've been anxiously waiting for over 6 weeks!
I only have 3GB of HDD space left, so it is Touch & Go every day
