Originally Posted by jtktam which Green drive is it? WD or Seagate?
i had nothing but troubles with WD green drives..
I have been running RAID 1 since it was available as an option on ICH chipsets.. now I run z68 motherboard and using the built in SSD caching feature (Smart response tech) and it works wonderfully.. you should consider that
-joe |
Well I did say it's a WD green drive at the end of my post and it hasn't had any problems for 2 years I've had it(yes I still back up the info on it). Also if you took a look at my system specs drop down you'd see that I'm running an AMD system and caching isn't possible unless I buy a synapse or similar drive.
