Old March 9, 2012, 09:41 PM
misterlarry's Avatar
Default SSD for Older Model Mobo???
Been out of tweaking and playing for a while. Just too busy to even be on the board much but I could sure use the help of the community on this question. I'm trying to determine if I can put the SSD listed below into the current build shown in my signature.
Mushkin Enhanced Chronos MKNSSDCR120GB 2.5" 120GB SATA III MLC Internal Solid State Drive (SSD)
I checked by BIOS and it does have an option to enable "Sata AHCI" mode and I want to do a fresh install of Windows 7 Professional 64 bit on the SSD (I'm hoping that I can call MS and tell them that my laptop is dying and that I want to transfer my OEM copy to my desktop). Am I good to go or do I need to upgrade my whole system to use this SSD?
I know that I'm in the wrong thread with this but I'm also looking to stick the following GPU into the case to replace my rather dated 8800.
EVGA 01G-P3-1556-KR GeForce GTX 550 Ti (Fermi) FPB 1GB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Any info would be greatly appreciated as I don't really want to pop for an SSD if it won't work in my current system. Thanks everyone.
Asrock Z68 Extreme3 Gen3 - Intel i5 2550K @ 3.4 GHz - Corsair H80 CPU Cooler- 4x4 GB G.Skill Ares DDR3 1600 - EVGA GTX560 Ti
1x120 GB Mushkin Chronos Enhanced SSD - 1x500 GB Seagate Hybrid Momentus - 2x500 GB Seagate Barracuda 7200.11 - Pioneer DVR-212D - Antec P182 - Corsair TX650 - 22" Hanns-G - Windows 7 Pro 64 SP1
The world is your oyster. Shuck away my friend, shuck away!
Old March 9, 2012, 11:16 PM
Bungwirez's Avatar
You can add that SSD and will see improved performance,
except that you won't see the top speeds from Chronos owing to the the fact that your 775mobo doesn't have any SATA III ports.
It'll still work backwards compatible.
BTW: I've been using that exact model SSD for about 6 months. Never had any issues.
As for the GPU. sure, why not. 550 is a cute little number.
I would just look for an EVGA model ending in AR -- indicates lifetime warranty.
If you don't like funerals, don't kick sand in Ninja's face
Old March 9, 2012, 11:47 PM
dont worry about sata3
you will see a big improvement
personally i would get something in the 560ti range
wait a few weeks for price drop
gtx780 paperlaunch commin
you can always tranfer the ssd later if you upgrade
bigest upgrade for daily use is an ssd
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old March 15, 2012, 08:59 AM
Thanks for the help guys. I ordered the 560 Ti also. Also purchased a 500 Gb Seagate Hybrid HDD. Looks like I will have lose one my existing HDDs unless there is a way to add another Sata or split one. Is such thing possible? Thanks.
Old March 15, 2012, 03:55 PM
you can also install SATA III upgrade card if you want to feel the speed difference.
Old March 18, 2012, 05:12 PM
Purchased this card to add Sata III capability to my old mobo.
Syba 2 Port SATA III PCI-Express x1 Card (SY-PEX40039)
So if I'm thinking correctly, after backing up photos, docs, etc, I should be able to:
1) Power up with current boot - enable AHCI in Bios - shut down
2) Add the above card
3) Plug the Mushkin SSD & Seagate Hybrid into it & install drives in case
4) Boot from Windows 7 Install Disk
5) Re-name Windows XP directory on current boot drive
6) Set SSD as boot drive in Bios
7) Install Windows 7 to SSD - shut down
8) Install new EVGA 560 Ti video card
9) Re-boot and upgrade drivers, etc.
10) Re-install apps & games
Does this sequence sound about right? Thanks again in advance for any help. I hate frying things and/or beating my head against the wall.
Old March 25, 2012, 12:35 PM
aaa, says on wiki that Intel P35 does not have PCIE 2.0 only 1.1 so your card will not transfer more than 200MB/s at read. In this case you might want just to leave it on the regular sata port on the Mobo and just enable AHCI mode.
[WTB] 5870 EK nickel plated acrylic model full cover water block (reference model) Lima Buy/Sell & Trade 4 October 4, 2010 10:33 AM
IBM Model M Appreciation Zink Peripherals 9 March 9, 2010 01:13 PM
[WTB] older gaming mATX mobo, cpu, gpu + PSU for crazy cheap donimo Buy/Sell & Trade 1 January 12, 2010 11:44 AM
I could be a model mailaw Off Topic 15 April 27, 2009 11:08 PM
FS-s939 X2-3800, OCZ ram, Ac Freezer 64 Pro, ASRock mobo, DFI mobo, Asus mobo..more stoanee Buy/Sell & Trade 14 June 7, 2008 06:24 PM
