Old February 26, 2012, 01:19 PM
Default SSD's on SATA2?
Hi does SATA2 compares to SATA3 for SSDs? Does the 3gbps hinder an SSD's maximum potential?
Old February 26, 2012, 09:40 PM
generally, if you're getting a sata iii drive, yes.
sata iii drives are capable of higher bandwiths than the limit of sata ii.
however, it shouldn't be a reason not to buy an ssd.
Old February 26, 2012, 10:14 PM
your not gonna notice a difference sata2 vs sata3
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old February 28, 2012, 06:49 PM
thanks guys, I just installed the SSD today, but for some reason I am missing 30gb of disk space. It says 80gb free out of 120gb after disabling page file, and hibernation. The only thing i have install so far is windows and it only takes 10.7gb
For SSD is SATA 3 worth it over the Sata2 TedShackley Storage 6 November 15, 2011 12:39 AM
corair f60 sata2. first time using a ssd, need help Your_friendly_gamer Storage 6 July 18, 2011 05:33 PM
where to buy a 9.5mm SATA2 optical caddy? cruisx Off Topic 4 July 12, 2011 12:45 AM
Sata - Sata2 tec}{ine Storage 4 June 25, 2008 01:36 PM
