Old February 10, 2012, 08:42 AM
Default Making the jump from Caching, to Raid-0
Hey guys, long time HC reader but first poster here.
I have a crucial c300 64gb that I am currently using for caching and I plan on buying two more, and using them in a raid array. I have a few questions that my research didn't quite clarify.
  • How do I uninstall Intel smart response caching, and prepare my drives to start a raid array
  • Will uninstalling the caching software prevent me from booting
  • How do I configure a raid-0 array with 3 ssd's
If anyone has suggestions I'd really appreciate tips!
Edit: spelling
Old February 10, 2012, 09:55 AM
just disable the acceleration in the intel management app and you are good to go
-joe
Old February 10, 2012, 10:24 AM
Thanks joe, any idea on how i would configure raid-0 in my bios? and how to wipe the ssd
Old February 10, 2012, 02:58 PM
There should be a disk management option in your bios, it really depends on which motherboard/manufacturer you have you can look up a guide based on your motherboard. I wouldnt worry about wiping your drive, when you setup the raid 0 array it will do it for you.
Old February 10, 2012, 04:02 PM
Once you disable the caching, right click on the SSD drive in the intel management console.. i don't remember the exact option, but it will be like "return to normal" or something to that effect.. it will wipe the SSD so you can use it like normal
-joe
X58 and caching? Dzzope Storage 5 December 30, 2011 01:44 PM
Linus, SRT-Caching r2yneth CPU's and Motherboards 4 December 23, 2011 03:15 PM
Will a new GPU be a big enough jump? Lyxtwing Video Cards 13 January 1, 2011 09:34 PM
Jump to Eyefinity or not? CMetaphor Video Cards 38 October 9, 2009 04:17 PM
Should I jump to i7? GT_Forthelulz New Builds 12 August 7, 2009 10:31 PM
