Old February 8, 2012, 05:18 PM
Default Western Digital Caviar Blue
What are the cables i will need to run this drive?
Newegg.com - Refurbished: Western Digital Caviar Blue RFHWD3200AAJS 320GB 7200 RPM 8MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Old February 8, 2012, 05:21 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
A sata data cable, free sata port on your mobo and a not in use (aka "free") sata power cable on your power supply.
Old February 8, 2012, 05:45 PM
Will a 6GB/s SATA cord work on a 3gb/s Hard Drive?
Old February 8, 2012, 06:13 PM
yes. hi.
Old February 8, 2012, 07:19 PM
AkG's Avatar
AkG AkG is offline
Yup they are backwards compatible. In fact I usually use 6'ers instead of the older 3'ers regardless of the storage unit....as they are a higher grade cable...and it makes things sooo much easier only having to have ONE pile of cables instead of TWO. ;)
Western Digital Caviar Black or Velociraptor? Jacka Storage 13 July 23, 2009 06:56 PM
