Old March 16, 2008, 04:56 PM
Cptn Vortex's Avatar
Default Weird Spin up noises
So this is really begining to annoy me.
I have a ton of drives in my system. Never been a problem. But I installed Vista 64 bit, works fine. However, I get this strange issue every once in a while.
Essentially I hear a little click or a chirp. Then the sound of the drives spinning up, then another little chirp. I am SURE that this is coming from my RAID 0 Array. It happens about once every minute. Also, when this happens, in between the time the spin up sound and the second chirp, I have a small little lock up, I can't type or click on things.
This doesnt happen all the time, though. It seems to be only once or twice a week, and then it does it for a few hours.
I have disabled SMART status in the BIOS, and can't think of anything else. Could it be some stupid Vista setting???
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old March 16, 2008, 05:05 PM
SMART is probably a good thing to leave on, as it can warn you of a bad disk.. Does the event log show any issues with "disk" or you RAID controller?
Old March 16, 2008, 05:16 PM
3.0charlie's Avatar
Windows updates?
I would re-enable SMART and double-check all your drives.
Run HD tach and try to recreate the noise?
Run Hitachi's Drive Fitness Test for defects.
Back-up the data just in case?
Old March 16, 2008, 05:19 PM
Ok I will give all that a try. I am currently De-fragmenting the data partition (about 750gb) and we'll see what I can do from there on. I have a free 500GB drive that I can back up most of the stuff onto. Hope it's not a drive problem though!
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Old March 16, 2008, 05:46 PM
JD JD is offline
Have you checked the power settings in Vista? I know by default it turns off the hard drives after like 20 minutes, so maybe that's it?
Also, do you have the latest drivers from Intel?
Old March 16, 2008, 07:57 PM
Yes I see that it was set to 20 minutes, which I have changed to 999999 minutes now haha. It is still de-fraging (this is going to take a long time) so I will see if this fixes the oddity later
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Old March 16, 2008, 09:23 PM
Defragmenting an unreliable hard drive is not the best idea. One small hardware error in the drive (of the sort that would normally be easy to smooth over) and it could corrupt everything on the drive.
Old March 16, 2008, 10:05 PM
Hmmmmm. I pray
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Old March 17, 2008, 06:38 AM
JD JD is offline
I believe there's a "Never" option but 999999 should do I guess
Weird result from AC Accelero S1 install donimo Video Cards 24 November 3, 2007 08:46 PM
NEED HELP with a Biostar Motherboard on Vista 64 (weird bug) db23 Troubleshooting 3 October 1, 2007 02:08 PM
Overclocking E6600, weird results dosmond Overclocking, Tweaking and Benchmarking 4 June 24, 2007 10:12 AM
