Old January 25, 2012, 09:31 AM
Default Corsair SSD differences
Greetings! First forum post, so please forgive if this information is elswhere on the site. Still reading through the mountains of information here!
Corsair 60G SSD's come in two model numbers: F60GB3-BK and F60GB3A-BK.
Can someone tell me the difference between the two, and if one is better with regards to speed and long-term use?
Old January 25, 2012, 11:02 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
IIRC -"A" means it uses 25nm NAND, whereas the older ones use 32nm. Good luck finding anything besides the "A" model.
With that being said why are you going with such an OLD model? The original Force model uses the SF1200 controller. Force 3 uses SF2281. Performance 3 / Performance Pro uses Marvel 2nd gen controller (same with Crucial M4, Intel 510). ANY of these would be better options for all but the most ancient of systems.
Old January 25, 2012, 03:52 PM
It was my understanding that the F60GB3A-BK model is the Force 3 model that uses the SF-2281.
This is what I'm considering buying:
I was asking because the same site also lists the non-A model, though it is currently out of stock:
Differences between Noctua D14 vs C14 Mr. Sneaky Air Cooling 3 January 1, 2012 05:44 PM
Performance differences? Skozaa Video Cards 3 December 9, 2011 08:32 PM
Differences b/w System & CPU-Z cul8erppl Overclocking, Tweaking and Benchmarking 6 June 27, 2010 10:57 AM
CPU Temperature Differences silent1mezzo Troubleshooting 8 September 4, 2009 09:13 PM
SLI Temp differences Toronto122 Overclocking, Tweaking and Benchmarking 4 April 3, 2009 06:52 AM
