Old January 2, 2012, 06:37 PM
Default what would corrupt an MBR?
ran into this today on another computer. was relatively easy to fix. i was just wondering what could do it as i run defraggler fairly often.
thx
rob123
Old January 2, 2012, 06:49 PM
Running a defrag program more than once or twice a month is unnecessary. I defrag mine either when I remove large files (2gb) or more or about every 6 months or so.
It could be why or a hardware issue
Old January 2, 2012, 06:54 PM
KaptCrunch's Avatar
power source drive lost power before had chance to write leaving corrupted data
Old January 2, 2012, 06:58 PM
Improper shutdown can do it... power outage, etc... I've had it happen a few times.
Old January 2, 2012, 07:13 PM
so, should i shut it down through the windows "turn it off" and not the "press the power button thing"
thx
rob123
Old January 2, 2012, 07:22 PM
thx
rob123
uh ya
Old January 2, 2012, 07:56 PM
Birk's Avatar
LOL
Old January 2, 2012, 08:08 PM
Shadowmeph's Avatar
Yes alwasy do a windows ( or which ever Operating system) shutdown unless you can't
Old January 3, 2012, 07:34 AM
TopDogZero's Avatar
Isn't the case power button normally set to "shutdown " in windows? If you are using windows, when you push the power button does the PC go into the windows shutdown routine (windows is shutting down screen) or does it just shutdown instantly, just want to be clear on this point. For sure you'll have problems if your doing a hard shutdown.
Old January 5, 2012, 06:57 AM
this was my little one's computer. mine, i always do a "windows" shutdown.
he saw me do a hard shutdown on my server ( cuz it wont, wont shutdown "normally")
and he thought it was normal.
when he power button is pressed it does not go into the windows shutdown.
they are now doing the windows shutdown.
thx for the info
rob123
NVATA.sys - Corrupt or missing! Dr_BenD_over Troubleshooting 12 February 27, 2012 01:57 PM
Corrupt Windows Folder, Boot Error Toyuko Troubleshooting 17 February 21, 2011 09:42 PM
Maclean's: Montreal is a corrupt, crumbling, mob-ridden disgrace Sandro_Bit Off Topic 30 November 3, 2009 09:02 AM
Warning: Windows 7 beta could corrupt your MP3s Shadowmeph Press Releases & Tech News 12 January 5, 2009 08:02 PM
Corrupt Demo's automatic Gaming 0 November 22, 2008 05:17 PM
