Old December 28, 2011, 10:44 AM
Soullessone21's Avatar
Default RAID Help with Imaging
Ok I will keep this short
I want to Strip 2 120GB OCZ SSD's.
issue already have one fully loaded with my system.
I want to image it to the 2 drives when they are in raid.
Biggest issue. I have worked professionally on computers for 6 years but have never I mean NEVER even touched a raided system.
So I have a Crosshair V and want to make this work.
Should I imaged the system to my 2TB then Format the 2 drives?
Then how do I get them into a raid setup I know It should be easy in the bios.
After they are in a raid setup how do I image over from the 2TB should I use Norton Ghost and does it have support to image to the raided drives?
Thanks so much
Old December 28, 2011, 11:31 AM
supaflyx3's Avatar
First use acronis true image to make an image and save it to your data drive, then plug both SSDs in and run the raid setup in your bios, select striped (raid 0) and leave everything to the default values, it will format the drives for you. Then just fire up acronis and move the image on to your now created raid array.
Old December 28, 2011, 12:12 PM
what version of acronis do you prefer ?
Old December 28, 2011, 12:38 PM
supaflyx3's Avatar
I haven't used acronis in years, look up tutorials on youtube to see what they recommend.
Drive Imaging Questions keto Storage 1 November 4, 2011 10:29 AM
Question about disk imaging r0bc Storage 5 September 13, 2011 04:06 PM
Disc Imaging Software timbruun Storage 5 July 23, 2010 09:35 PM
Ghost/HD imaging software no_pulse O/S's, Drivers & General Software 27 December 3, 2009 07:32 PM
Disk imaging software. Il Duce Troubleshooting 6 December 21, 2008 10:27 PM
