Old December 7, 2011, 10:19 AM
great_big_abyss's Avatar
Default Imaging a Hard Drive
So I have three HDDs: A WD 500 GB Black, a 1 TB Green, and a 2TB Green. I'm currently using the 500GB as my system and install drive, and using the 2TB green as media storage. the 1TB is sitting in my computer currently doing nothing.
What I would like to do is this:
1) Create a back-up image of my system drive onto the 1TB drive.
2) schedule monthly backups of my system drive over that image.
What is the best way to do this? Can windows scheduler do it? Is there a good program to use? I've never created an image of an HDD before.
Old December 7, 2011, 02:46 PM
Acronis True Image is an excellent drive imaging program... Been using it for years.
Old December 11, 2011, 06:25 AM
same here. there is nothing like acronis.
AND, seagate puts out its own version of the software for free. not sure about western digital.
cheers
rob123
Old December 11, 2011, 07:15 AM
Galcobar's Avatar
Can't schedule backups or create incremental backups with Seagate's Disk Wizard or the WD Edition -- though both are based on Acronis, being free means they're limited. That said, I know Disk Wizard contains a link to buy the full Acronis at 40% off.
Old December 11, 2011, 08:05 AM
Another +1 for Acronis, but I'd recommend not having the backup drive hooked up at all times, so a power surge, virus that does low-level format, or PSU explosion doesn't take out your system drive and its backup at the same time.
Old December 11, 2011, 09:25 AM
gingerbee's Avatar
Acronis gets my vote too great bit of kit here
Old December 11, 2011, 09:30 AM
KaptCrunch's Avatar
echo the gringerbee man
Acronis ftw
note: don't mix data drives software with other HDD's brand software
old hard drive new pc? billy1599 Storage 8 December 4, 2011 05:36 PM
Drive Imaging Questions keto Storage 1 November 4, 2011 10:29 AM
Is my hard drive going to die? Blu Storage 5 September 23, 2011 08:43 AM
[WTB] DDR3 SODIMM, 2.5" Hard Drive, Hard Drive Enclosure TopDogZero Buy/Sell & Trade 2 May 20, 2011 04:24 PM
