-   -   Can a Sata II Based Laptop read a Sata III SSD (http://www.hardwarecanucks.com/forum/storage/48878-can-sata-ii-based-laptop-read-sata-iii-ssd.html)
Monster1307 November 29, 2011 01:23 PM
Hello everyone, I would like to know if I can put a SATA III into my laptop that is a SATA II...
Thanks for the help!
chubaka November 29, 2011 01:34 PM
it will work since they are compatible with each other... it will run at sata 2 speeds.
Monster1307 November 29, 2011 02:55 PM
AWSOMMEEEEEEEEE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! That means I can buy a larger SSD to put in my tower and put my old SSD in my laptop!! :) Awsome!! :P
Thanks for the quick reply!
pitz December 5, 2011 03:31 PM
Fully backwards and forwards compatible. Interface speed isn't really a big deal with SSDs because they are generally bought for random read performance, rather than sheer linear sustained read or write speeds.
Basically, anything with a SATA connector will plug into anything with a SATA connector. Even the 150mb/sec "SATA" interfaces (not even SATA-2) can benefit from a SSD enormously.
