Old November 26, 2011, 10:18 AM
Default Confused about SSD please help.
So I'm planning on buying an SSD but I am confused with the difference between Newegg.com - Crucial M4 CT064M4SSD2CCA 2.5" 64GB SATA III MLC Internal Solid State Drive (SSD) with Transfer Kit and Newegg.com - Crucial M4 CT064M4SSD2 2.5" 64GB SATA III MLC Internal Solid State Drive (SSD). Do they both run on regular pcs or does the first one run in a pc and the second one only for a laptop? Thanks :).
Old November 26, 2011, 10:21 AM
Shadowmeph's Avatar
I think that they both would be able to run on PC or Laptops
Old November 26, 2011, 10:22 AM
So why is there a 10$ difference between them? ;o
Old November 26, 2011, 10:28 AM
Shadowmeph's Avatar
one has a Data Transfer Kit and the other doesn't so basically you are paying 10 dollars for software
Old November 26, 2011, 10:29 AM
ohh awesome thanks :D.
Old November 26, 2011, 10:49 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Bingo. You can clone your old drive to the new one via the included software and USB cable. Without needing to yank the old drive first. Some people want that and will consider it a cheap investment.
YMMV
Old November 26, 2011, 10:52 AM
sswilson's Avatar
Well worth the extra cash for folks upgrading a laptop HDD, but (IMO) not worth it for a standard desktop swap.
Old November 26, 2011, 11:01 AM
But would it be compatible with a regular pc? or no laptops only?
Old November 26, 2011, 06:25 PM
Galcobar's Avatar
The transfer kit is to accommodate laptops which only hold one hard drive or don't have any free bays -- a PC you can drop both drives in and clone from one to the other. The "laptop transfer kit" lets you hook the drive up externally, which isn't necessary on a PC. It's an addition, an accessory to the drive and not part of the drive itself.
Old November 26, 2011, 09:22 PM
Thanks you cleared up my question :)
So confused.. xD Chef New Builds 1 November 21, 2011 09:57 PM
I am so confused about RAM bonanza2000 RAM 6 February 1, 2011 04:25 AM
which ram to get confused hellokittyonline2 RAM 4 December 26, 2010 12:45 AM
I'm A Bit Confused shayan288 Gaming 14 November 21, 2010 09:45 AM
Confused... encorp CPU's and Motherboards 6 April 28, 2008 11:15 AM
