Old November 19, 2011, 12:18 PM
Nevakonaza's Avatar
Exclamation Suitable Raid card?
Hey guys,
Would this Raid card be suitable for 2x OCZ Vertex 2E 60GB ssds in Raid 0?
Startech Storage Controller (RAID) SATA-300 300 MBps.. | Ebuyer.com
My current motherboard has onboard raid, but when I use that the speeds from my SSDs are poor, I don't think my onboard can handle it.
Old November 19, 2011, 01:03 PM
Perineum's Avatar
I would bet the ICH10R you have on your motherboard is better than that RAID card.
I also would not expect that you should get slow speeds when using your ICH10R raid
Old November 19, 2011, 03:10 PM
make sure you don't do raid with the gigabyte ports, probably is a second sata controller usually by Jmicron that can do some raid, make sure the sata ports belong to the Intel chipset not some other crap chip.
Old November 19, 2011, 05:11 PM
Keywork's Avatar
The Intel chipsets are surprisingly decent for RAID. Also, when it comes to RAID cards, DO NOT SKIMP.
Need help finding a suitable router Lpfan4ever Networking 12 July 28, 2010 07:13 AM
RAID Card - Yes, No, Maybe? AmuseMe Storage 12 December 17, 2009 06:25 PM
do I need raid card? bumfloss Storage 11 June 27, 2009 05:14 PM
do i need a raid card for a server. kyle_L Storage 15 April 1, 2009 12:21 PM
looking for a raid card that does 0+1 cujo Storage 0 March 10, 2008 11:14 AM
