Old November 13, 2011, 08:09 AM
Default HD partition organization without formatting
I want to reorganize the partitioning on my HDD.
Years ago I used partition expert or magic 2003.
What software would I use now? any recommendations?
thanks
Old November 13, 2011, 08:19 AM
If you're running Windows Vista/7, the built in disk manager utility can do it.
Otherwise there are plenty of freeware options and Linux distros capable of this. Easeus is one that works in Windows, UBCD has a few Linux based utilities that work as well.
But as always, backup anything important before moving partitions - just in case.
Old November 13, 2011, 08:25 AM
The built in manager is crap though. Easeus has the best free solution.
Old November 13, 2011, 08:43 AM
JD JD is offline
And for paid solutions, Acronis Disk Director 11 works great.
Old November 14, 2011, 07:37 AM
I use Parted Magic, linux based, but works on any HDD or SDD. Has 32 or 64 bit versions.
Formatting a HDD Myst88 Storage 5 March 25, 2011 12:45 AM
SSD How to merge unallocated partition to primary partition in Windows 7 Mark Troubleshooting 22 May 14, 2010 04:32 PM
What can I do to improve my loop's organization? Z Overlord Water Cooling 11 August 31, 2009 12:14 PM
New Site Organization. BALISTX Suggestions & Feedback 13 July 22, 2008 04:27 PM
Fat Partition to NTFS Boot Partition PaxeSalute O/S's, Drivers & General Software 1 May 2, 2008 01:28 PM
