<~----> How can I clear my HDD's? - Hardware Canucks
Old November 4, 2011, 11:20 PM
Pabz0r545's Avatar
Default How can I clear my HDD's?
I have 2 320gb Samsung spinpoint hard drives that I would like to completely wipe so they can be sold on here or kijiji. The only problem is that the computer they were hooked up to has been parted out partially. How can I go about running a program like boot and nuke?
Can anyone help me out I've never done this before and don't want to accidentally nuke my SSD boot drive. :P
Old November 4, 2011, 11:24 PM
Supergrover's Avatar
Have a look at this post , you should be able to just hook them up to your existing rig and wipe them with the program of your choice.
Reminder: Properly Wipe Storage Devices Before Selling
R.I.P.
Old November 4, 2011, 11:40 PM
Pabz0r545's Avatar
Yeah that's where I got the idea. I am just unsure about the process. Is it really just as simple as connect the power and sata cables and then run the program or do I have to make any bios changes or ?
Thanks.
Old November 4, 2011, 11:50 PM
it's as simple as that.
Old November 4, 2011, 11:58 PM
Thanks.
Yup just hook them up power on they should be detected by windows with a popup window. Open the program of your choice point it to the drives do your thing.
R.I.P.
Old November 5, 2011, 12:03 AM
Pabz0r545's Avatar
Awesome I'm in Eraser right now, just hooked em up. A strange thing though. One of the drives is partitioned. Do I need to do anything special first?
Old November 5, 2011, 12:15 AM
Pabz0r545's Avatar
I keep getting this message
Status Completed with Errors
Error The program does not have the required permissions to erase the unused space on disk. Run the program as an administrator and retry the option.
I tried running it as an admin and still nothing :(. Googling for a solution right now.
*edit again. I'm a noob I didnt fully close the program was just xing out of it.
[Mod] Clear Sky Complete artistpavel Gaming 4 May 6, 2010 07:21 AM
WP7S are more clear now martin_metal_88 Reviews & Articles from the Web 2 April 4, 2010 10:41 AM
Clear QAM sam101p5 HTPC Systems & Software 0 July 5, 2009 01:19 PM
Had to clear CMOS... why? somecanadianguy Overclocking, Tweaking and Benchmarking 12 June 6, 2009 09:24 AM
STALKER Clear Sky + 1080p? Not possible? lowfat Gaming 0 December 3, 2008 07:32 PM
