Old November 3, 2011, 02:30 PM
Default Drive Imaging Questions
-I've never done it
-I have a RAID0 array that I want to image
-can I take a RAID0 image and put it on a 'standard' HD?
-I want to know what software you recommend. Freeware if possible, low cost OK, also best-of-the-best recommendation
-I don't know where to start, ie., how to make the image and then how to put the image on a fresh HD
-can I put the image on a fresh built system (assuming from DVD or?)
2600K @4.6
P8Z68-V Pro Gen3
Patriot Div2 Viper Extreme PC3-15000 4GBx2 (1866 9-11-9-27-2)
Gigabyte GTX780
Caviar Black 1TB x2 RAID0
Corsair Gold 850W
Corsair H80
Corsair 600T Graphite
Old November 4, 2011, 10:29 AM
francisw19's Avatar
I run a pair of OCZ Vertex 2's in RAID0 and I regularly image them in case one/both fail. In general, when you image the disk or partition, you'll end up with an archive file - the extension will usually be proprietary to the software you used. To store these archive files, you should have another hard drive, preferably eSATA or USB 3.0 if you want to go external, but another internal drive will be fine too. It is possible to keep the archive on optical media (DVD or Blu-Ray), but for long-term storage and convenience, an external hard drive is my personal preference.
When you are ready to restore the image, usually you can restore non-system disks in the OS environment. However, if you want to restore the system disk, you'll have to use a boot CD (which is normally provided) as you obviously can't over-write the system disk while it's booted. Normally, the restore process is just a matter of selecting the backup archive you want to restore and then choosing the disk you want to restore it to.
Presently, I use Image for Windows (IFW) to image my disks. In my use with it, it's been very reliable - no crashes with the software or anything. I've done hundreds of backups/restores and have NEVER had a bad image thus far. It's very light-weight (no bloatware) and has worked very well for me. And I've had no issues with RAID disks, external disks, etc...
Also, the image can be captured while running Windows, so there is no need to tie up your PC - you can continue to use it while being backed up. Again, restoring the system disk can't be done while running Windows, so you must use Image For Linux as it runs from a boot CD and is included when you buy IFW.
You can check these out at: TeraByte Unlimited :: Boot Manager :: Partition Manager :: Drive Image :: Disk Copy :: Drive Wipe :: Hard Drive Utilities. IFW is not free, but is around $40 or so.
I've also run Acronis True Image, Paragon Backup and Shadow Protect Desktop. In my experience, Acronis True Image was somewhat unreliable and had some issues with the Boot CD picking up hardware. Getting help with customer support was very difficult. It's quite popular, however, so it's likely you'll come across information about it if you do some googling.
Paragon was so-so...it seemed to capture images well, but at the time there were some limitations on 64-bit Windows that put me off it. This was several years ago, so this may have changed in that time.
Lastly, Shadow Protect Desktop is very good...I'd go so far as to say this could be considered the "best of the best". VERY reliable software and very good management of disk images. The major down-side is that it's very expensive compared to similar software and it has a pain in the butt activation that you must deal with to install in Windows.
Regarding restoring your RAID0 disk to a single disk, I've never done such a thing. Off the top of my head, the biggest complication will be to make sure your new disk's capacity is larger than your RAID0 setup. Some software has to ability to restore to a smaller disk (provided the actual data on the disk can still fit) by simultaneously shrinking the partition during restore to fit.
I hope this answers a few questions. :)
Question about disk imaging r0bc Storage 5 September 13, 2011 04:06 PM
Disc Imaging Software timbruun Storage 5 July 23, 2010 09:35 PM
Beginner Builder, Optical Drive Questions Charmster Storage 3 June 17, 2010 10:32 PM
Ghost/HD imaging software no_pulse O/S's, Drivers & General Software 27 December 3, 2009 07:32 PM
Disk imaging software. Il Duce Troubleshooting 6 December 21, 2008 10:27 PM
