Old October 30, 2011, 09:19 PM
Your_friendly_gamer's Avatar
Default is this normal for corsair f3 ssd?
Hi all,
I am not sure if this is supposed to show these numbers? I have updated all the drivers and I have the drive plugged into sata 3, but average transfer rate is 187?
Old October 31, 2011, 04:05 AM
any advice?
Old October 31, 2011, 08:24 AM
Beastylemon's Avatar
I have the same SSD so..
First, I'd check to see if your controller is set to ACHI Mode.
IF NOT IN ACHI MODE, DO NOT CHANGE IT YET
Look for an online tutorial of how to change IDE to ACHI
If you change it without preliminary preparation, you WILL BSOD on boot
Then, I'd disable the C3 and C6 states of the CPU (not C1E)
Many reports of these CPU states making the hard drive numbers all wonky
Then check if there is any difference
Corsair 650D / MSI Z77A-G45 / Intel i7-2600k / ASUS GTX780 / 4X4 Gig Corsair Vengeance DDR3-1600 / OCZ Vertex 4 120GB x2 / Corsair H100 / Corsair AX1200W PSU
Samsung U28D590D + ASUS VN248H x 3/ CM QuickfireTK MX Blues / Razer DeathAdder /SteelSeries 4HD
Old November 1, 2011, 08:44 AM
UPDATE: I just did that test myself, and I'm receiving pretty much the same numbers as you (assuming your running that as your OS drive).
But for me its a little different. See when your SDD jumps to 400 and stays there for abit? Mine stays there twice as long, but it's near the end of the test unlike yours which is at the beginning. Mine also is at 425-450 when that happens.
And when its not up there, mine shows it hovering around 200-250
Are these temp normal for a H50? lanken123 Water Cooling 5 June 28, 2010 10:12 AM
Phenom II 545 x2 normal temps? ubernoobie Air Cooling 2 February 20, 2010 05:06 PM
40C mobo normal? Pokeguylow CPU's and Motherboards 6 June 4, 2009 01:04 AM
Is this Normal? Soultribunal HardwareCanucks F@H Team 12 May 27, 2009 04:43 AM
CS:S ti normal program Long John Silver Gaming 5 June 21, 2007 07:32 PM
