Old March 2, 2007, 08:35 AM
Babrbarossa's Avatar
Default High heat does not damage HD's
A somewhat interesting finding by Google researchers (hee hee! "Google reasearchers") found that high heat doesn't appear to correlate with HD failure. The sampled from 15 to 45 celsius.
Read the article at PCWorld
Old March 2, 2007, 08:40 AM
Gav's Avatar
Gav Gav is offline
Administrator
Ya, I read that a while ago, fairly interesting. I've never put much effort into cooling my drives. I usually have good enough air flow in my case that I ever felt the need to have additional HDD cooling.
Old March 2, 2007, 10:24 AM
Deathspawner's Avatar
45C is not that high... my 750GB Seagate reaches 53C for a joke. I had to throw in an HDD cooler to make sure it didn't 'splode.
Techgage.com | Editor in Chief
Intel Core 2 Quad Q9450 @ 3.20GHz, ASUS P5K Premium WiFi-AP, OCZ 8GB PC2-6400, EVGA GTX 285 1024MB
Seagate 500GB, 750GB & 1TB, Pioneer 22x ODD, Corsair 1000HX, Thermalright Ultra-120, CM Storm Sniper
Dell 2408WFP 24", ASUS Xonar Essence STX, Ultrasone PRO 750, Gentoo Linux (KDE 4.4, 2.6.32 Kernel)
"Take care to get what you like, or you will be forced to like what you get!" - H.P. Baxxter
Profiles: Last.fm | Xbox Live | Steam
Old March 2, 2007, 10:37 AM
Yeah- I wonder why they didn't sample a wider range-- those whacky Google researchers
Old March 2, 2007, 12:11 PM
sswilson's Avatar
Yeah, 45c doesn't sound like an extreme temp to me.....
It's high, but certainly not above the realm of possibilities.
How about trying a 3 drive array stacked close together @ 35c ambient & poor ventiliation over them????
That would be a test!!!
Old March 2, 2007, 01:44 PM
Gav's Avatar
Gav Gav is offline
Administrator
I have 3 drives stacked with no issue so far.
Seagate 40gb.
Seagate 320gb.
Maxtor 300gb.
Old March 2, 2007, 02:42 PM
Very interesting article, I would have like to see more data for higher temperatures as well.
Old March 2, 2007, 09:33 PM
Seagate 40gb.
Seagate 320gb.
Maxtor 300gb.
Those drives wouldn't put off much heat though. 500GB+ are the drives that put off a LOT of heat. I could see 3x750GB giving sickening results.
Still out of curiosity, what's the temp of the drive in the middle?
Old March 8, 2007, 12:20 PM
Misoprostol
Guest
Posts: n/a
45C is nothing.... I'm only concerned about a drive when it's hot enough I can't hold my finger on it for 10 seconds.
Heat Issue Lyxtwing Video Cards 8 March 14, 2008 08:35 AM
what is a decent air heat sink Shadowmeph Air Cooling 13 January 8, 2008 06:46 PM
Curious about buying heat pipes. chibi_man Water Cooling 2 December 12, 2007 11:00 PM
how to damage a cpu? magictorch Overclocking, Tweaking and Benchmarking 8 July 28, 2007 08:31 PM
Modifying my CPU Heat Sink??? mattydies Water Cooling 8 June 25, 2007 09:03 PM
