Old October 22, 2011, 05:11 PM
Your_friendly_gamer's Avatar
Default Crazy temps on corsair 3 ssd
Hey all,
I will be installing windows for the very first time on a Corsair Sata3 120 GIg hard drive tonight. I am going to be connecting it with the sata 3 port on my motherboard which is a z68x-ud4-b3. So I just turn on my pc, boot from the cd and install windows on the ssd? Or do I need anything else configured?
Thank you.
PS. It's only possible because of zzlee, he leant me his gfx.
Old October 22, 2011, 07:55 PM
Jonesy's Avatar
Instal windows.as you would on a mechanical drive.. Nothing special about it
Old October 23, 2011, 06:34 AM
I have installed windows successfully on the ssd, and it works wow amazing. SUper fast! The only thing is, hwmonitor it shows temps of 128 degrees celcius. I opened the case and touched the drive a few times and it seems to be cool, not buning at 128 degrees. any other way to check the temps for the hd?
Old October 23, 2011, 07:00 AM
sswilson's Avatar
There's no reason for an SSD to be any warmer than the ambient inside your case, in fact, other than actually being on fire, I can't think of a single physical reason to allow it. I'd just write the high temps off as a bad reading from the software.
Old October 23, 2011, 08:06 AM
Jonesy's Avatar
It is an error with the read out. Lookin at your other temps you are prob running around 30 degrees or so. If you want to verify temps you can tape on a probe.
Old October 23, 2011, 11:11 AM
Iceman's Avatar
I had the same temperature issue with my 60GB Corsair Force 3 drive. It is resolved with the latest firmware update, available here.
Antec P182 - Gigabyte EP35 DSR3 - E8400@3.6Ghz - 2x2 GB GSkill F2 6400CL4 - HIS HD 5770 - Audigy 2 - Corsair Force 3 60GB - 7200.11 500GB - Silencer 610W - Windows 7
Old October 23, 2011, 12:19 PM
I will definitely try this tonight or tomorrow as I am at work right now. Quick question I was reading the pdf file, did you have to re-install windows on your hd afterwards? Any issues?
Currently I ahve firmware 1.3
Old October 23, 2011, 12:45 PM
My Force 3 is on firmware 1.3.2 and it still shows 128C, not that it matters because the SSD itself has no temperature sensor. (read link)
The firmware update for the force 3 is actually very simple, there is no need to reinstall anything. The advice is that if your SSD is stable, you don't need to update your firmware. Just ignore the temperature reading.
My Corsair Force 3 Runs at 128C HOT - The Corsair Support Forums
Old October 23, 2011, 12:51 PM
Thank you, this is my 2nd ssd, the first one was force2 and well i didnt have it for very long. I absolutely love this hard drive. Friggin fast in everything. I was a bit skeptical buying a sandforce ssd because of the issues that have been reported, but I got a good deal on it so went with it. I love it so far, and no bsod's so far as well. So I am very happy. Thank you!
Old October 23, 2011, 01:00 PM
ZZLEE's Avatar
Hows the Vid card working fore you ?
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Installing windows on an ubuntu drive magictorch O/S's, Drivers & General Software 13 August 10, 2011 12:38 PM
[WTB] DDR3 SODIMM, 2.5" Hard Drive, Hard Drive Enclosure TopDogZero Buy/Sell & Trade 2 May 20, 2011 04:24 PM
OWC Mercury Extreme SSD - First Look at a 50GB SandForce Drive [anandtech] gingerbee Reviews & Articles from the Web 0 February 26, 2010 08:17 PM
OCZ Technology to Deliver SandForce-based Solid State Drive Solutions FiXT Press Releases & Tech News 0 November 10, 2009 12:35 PM
Installing Windows Vista to a SATA3G hard drive Mr. Gruntsworthy Storage 19 October 6, 2008 09:50 PM
