Originally Posted by Galcobar The issue with OCZ isn't an issue with OCZ. The problem is that OCZ, like most SSD manufacturers currently, uses Sandforce controllers and Sandforce controllers are...tempermental. If they get along with your system, a SF controller is the fastest thing on the market and reasonably stable. If they don't, an SF controller is the fastest thing on the market until your machine crashes. Unfortunately, what exactly causes this incompatibility is unknown -- and compatibility cannot be predicted from component brand, model, chipset, etc.
OCZ sees a lot more of these complaints because it is by far the largest SSD manufacturer using Sandforce controllers.
As for compatibility of SSDs, they're (at least when the controller co-operates) just like hard drives -- as long as you can hook them up they'll work, and are backwards compatible with older SATA specs. I'm running an M4 on SATA II now. Your G33 chipset supports SATA II, so you won't get the full benefit of the M4 but in terms of day-to-day use the additional bandwidth of a SATA III matters much less. The jump in OS and application responsiveness is almost entirely due to small file speeds which by their nature don't stretch even SATA II's bandwidth. The effect on your computer, however, is incredible. I won't go back to an HDD-based OS if I can at all avoid it. |
Just to add to that, the Crucial M4 doesnt use the SF2281 controller. It uses the MArvel controller. So its a moot point and nothing you have to worry about if you get the M4. M4 (and Intel 510) is the drive I recommend for all first time SSD users. You really cant go wrong with it no matter what OS, what mobo or what drivers you are using....it can take care of itself like no other in its price range.
