Old October 4, 2011, 03:16 PM
Exclamation How do i know if my "Drive Controller" is running in "AHCI mode"?
I have to update my Corsair Force Series 3 60Gb SSD and then i need to have the "drive controller" in "AHCI mode". I dont know if i have to change it using this: Error message when you start a Windows 7 or Windows Vista-based computer after you change the SATA mode of the boot drive: "STOP 0x0000007B INACCESSABLE_BOOT_DEVICE" or if its already running in AHCI mode...
If my "Drive Controller" is not running in AHCI mode, do i really need to change it? Is it that important? Will something happen if i dont change it?
Awesome work on the channel btw Linus!
Old October 4, 2011, 04:16 PM
Linus's Avatar
If the manufacturer recommends a particular mode, then USE it. You can always change it back once you're done updating.
Please note: I am not here to provide official NCIX support on these forums.
For faster (and official) NCIX service please contact our customer care team at www.NCIX.com (Canada) or www.NCIXUS.com (USA)
Heatware: http://heatware.com/eval.php?id=25647
Old October 8, 2011, 09:54 PM
You should be able to check whether you're using AHCI in the BIOS?
If you want or need to change the IDE (emulation?) mode to AHCI, you can use these steps. Mostly changing the registry and that way you don't need to re-install.
http://www.tomshardware.com/forum/24...ata-ahci-vista
Change IDE to AHCI in BIOS - Much better performance - Windows 7 Forums
Aren't recent BIOS settings using AHCI by default yet? :)
Tags
achi , corsair , drive controller , force seiers ssd , update
Cannot access hard drive: "disk boot failure" nlts Troubleshooting 10 May 13, 2011 07:15 AM
"Wii 2" Codenamed: "Project Cafe" BFighter Gaming 5 April 24, 2011 10:16 AM
"Precision aim mode" for logitech mice? blaze_125 Peripherals 17 November 16, 2010 08:14 AM
3d Vision goes from "gimmick" to "ubiquitous" The RealRollo Video Cards 28 October 21, 2010 03:55 PM
