Old September 30, 2011, 05:08 PM
supaflyx3's Avatar
Default Is it possible to have 2 raid arrays on 1 chipset?
I want to buy another 500GB drive to raid with my games and applications drive, i already have 2 intel SSDs in RAID0, is it possible to have a second array on the same chipset?
Old September 30, 2011, 05:15 PM
CMetaphor's Avatar
Quadfather
Short answer: Yes
Longer answer: As long as the extra ports are on the same Raid controller, then you should be able to add additional arrays.
Old September 30, 2011, 06:02 PM
Intel usually has 4 ports which will allow 2 arrays in a mirrored setup and I think stripe.
Old September 30, 2011, 06:21 PM
supaflyx3's Avatar
This is an nvidia chipset, and i want to run 2 striped arrays.
Old September 30, 2011, 06:30 PM
Eww wouldn't trust nvidia to raid.
Old September 30, 2011, 07:25 PM
supaflyx3's Avatar
Nor would i, but if it works, whatever. Haven't had any issues with RAID so far, just wondering if its possible to have two arrays. :P
Old September 30, 2011, 07:43 PM
Supergrover's Avatar
Well you just pooched yourself with that statement you do realize.
R.I.P.
Old October 1, 2011, 06:36 AM
"Quote This..."
What mobo are you using? Most mid and upper boards have 2 sata controllers. Mine (EVGA X58) has 4 ports on the intel ichr10 and 2 ports the jmicron jm363. You can plug the mech drives into the other controllers ports and use it's raid. Better performance.
Black belt in CAPS LOCK.
Old October 1, 2011, 02:38 PM
supaflyx3's Avatar
M2N-E, it only has the nvidia chipset.
Old October 14, 2011, 11:08 AM
yes it works fine, you can do two different arrays as long you have 4 different ports that are on the controller for the raid. on Nvidia boards usually they are in red.
Intel Chipset Driver Brings TRIM Support to RAID Setups FiXT Press Releases & Tech News 11 October 3, 2010 10:30 PM
Raid 0 on the SB750 Chipset Review Junglebizz Storage 8 June 5, 2009 02:18 PM
CPU + Chipset enaberif Water Cooling 10 January 23, 2009 11:48 PM
Bandwith vs modern raid arrays tzetsin Storage 2 July 19, 2008 05:01 PM
ESata dual raid enclosure = poor man's hardware raid? sswilson Storage 10 May 6, 2008 09:58 AM
