Originally Posted by JMCD I'm fairly certain it voids the warranty if you open up the enclosure, however if it doesn't I would suggest plugging it into your PC directly and see if that changes anything. |
It's plugged into a extra 4 port USB card I bought from NCIX, I'll try a new port but it seems to relate to this problem I had here,
Odd thing
Basically c:\$Mft (or any drive letter) basically means your drive is dying and I guess mine has hit the bucket I can try opening it up but i think I would rather collect on the warranty I have on it first of all.
