Old September 15, 2011, 08:02 AM
da_bradler
Guest
Posts: n/a
Default Rebuild Raid 0 array after motherboard switch?
I just ordered a new motherboard and I was wondering if my Raid-0 array is going to be easily transferable? the motherboards use completely different chipsets, one is a nvidia and the new one is AMD 990FX. is it as simple and setting the drives to raid in the new bios and it will show up?
Old September 15, 2011, 10:09 AM
dandelioneater's Avatar
I've done it no probllem with intel chipsets. Not sure about your situation though. Try enabling raid and try it out.
Old September 15, 2011, 11:13 AM
There is probably an option to import a foreign config but I can't find much in the way of people who have imported a raid to a 990fx board.
Old September 15, 2011, 11:48 AM
JD JD is offline
I doubt it would work.
I'd strongly suggest backing up everything on your RAID0 to an external drive before tearing apart the PC.
Old September 15, 2011, 12:37 PM
Perineum's Avatar
I second that. I don't think it would work.
Booting from new RAID 1 array in W7 Scart Storage 18 December 20, 2009 01:22 PM
Old Raid 0 Array, new Mobo mattydies Troubleshooting 3 December 18, 2009 11:21 AM
Missing RAID array iv:xx Troubleshooting 10 June 12, 2008 07:16 AM
9 drive ssd raid 0 array tzetsin Storage 3 May 3, 2008 11:03 AM
Raid Array Questions? Robscix Storage 13 December 5, 2007 03:59 PM
