Old September 13, 2011, 12:08 PM
r0bc's Avatar
Default Question about disk imaging
Right now I have my games installed on a 1TB Black. That drive is partitioned, its called E and F with my games on F. I'd like to image just F to a SSD, whats the easiest/best way to do it?
Old September 13, 2011, 12:32 PM
Perineum's Avatar
Acronis!
Old September 13, 2011, 12:40 PM
reinstall all your games!
Old September 13, 2011, 01:10 PM
r0bc's Avatar
Originally Posted by Perineum View Post
Acronis!
Will it let me do just that partition?
That's alot of downloading and what I'm trying to avoid.
Old September 13, 2011, 03:08 PM
Perineum's Avatar
Yes sir, I'm 99.5 % sure of that.
Short of that, if the games are on Steam then use the backup feature for each game.
I have all my Steam games backed up on a 2tb drive.... just in case.
Old September 13, 2011, 04:06 PM
Galcobar's Avatar
I used Gnome Partition Editor, aka GParted. Linux-based, can be had as an ISO so works off a CD or USB. Copy and paste the whole partition, and ensure it's properly aligned. Only issue is if it's a boot drive, in which case a little fiddling with boot records is required.
Slow disk to disk to transfer rates. CroSsFiRe2009 Storage 3 December 8, 2009 09:01 PM
Transfer rates from Disk to disk and usb? Sagath Troubleshooting 7 August 10, 2009 01:50 PM
Disk 0 and Disk 1 in Disk Management MorePower Troubleshooting 10 August 9, 2009 03:11 PM
Disk Boot Failure - Insert system disk and press enter? lanken123 Troubleshooting 5 May 13, 2009 07:23 AM
Disk imaging software. Il Duce Troubleshooting 6 December 21, 2008 10:27 PM
