Old September 12, 2011, 11:41 AM
Blu's Avatar
Blu Blu is offline
Default Delayed write fail message
I haven't found anything in the search and when I google it I just find people saying to replace the hd or it's a ram problem, but yeah I'm getting this screen alot,
When I'm doing nothing at all, I'll just leave my pc and come back and there it is. Should I test my hard drive for defects or get ready to replace it?...
Old September 12, 2011, 11:45 AM
misterd's Avatar
Sadly it's spyware. I just had to fix a staff members computer with that on there. Try scanning with Spybot or MBAM.
#hardwarecanucks on irc.freenode.net
fiat justitia ruat caelum
Old September 12, 2011, 02:10 PM
Galcobar's Avatar
Not necessarily -- you can also prompt the issue if by unplugging the drive while it's attempting to write. I discovered this while trying to rescue data off my latest SSD failure; it'll operate for a few minutes at a time. When it goes offline in the middle of a file copy, I unplug it for a few seconds to reset it and get that exact error message.
I'd do the malware scan, but if that turns up nothing run chkdsk or a more comprehensive utility such as Seatools.
Old September 12, 2011, 08:41 PM
Blu's Avatar
Blu Blu is offline
No viruses or malware/spyware showed up, it is one of my element external drives it's occuring on so I'm just going to say it's probably loosing power for a couple seconds...
Old September 12, 2011, 08:46 PM
turn off delayed writes.
What's the Maximum Read/Write of SATA II (3Gb/s)? Yamcha Storage 3 May 29, 2011 08:55 PM
cp fedex puro ups fail + canada computers fail _dangtx_ Off Topic 21 May 22, 2011 12:16 PM
slow SSD read/write speeds OuTR Troubleshooting 10 July 28, 2010 06:33 AM
Should I write a review of the 9600GSO 96sp? Unknownm Off Topic 7 August 29, 2009 05:33 AM
Interesting little write up Exmortis Overclocking, Tweaking and Benchmarking 4 February 7, 2009 06:29 AM
