Old August 28, 2011, 09:43 PM
Default Raid 0 question
I have a WD 640GB black which I am running out of capacity soon. It has dual boot win7/debian on it, plus all my data files in debian /home. I want to buy another WD 640GB black and run raid 0 with my existing one (which is about 2 yrs old). Can I install them without loosing my installations (os and data), or do I have to wipe the old one clean, create raid 0 and then load the os images and data files back?
Old August 28, 2011, 11:50 PM
you will loose everything to do raid 0
since they have to be reconfigured to work in raid 0
and the data is spread out on raid 0
this is the downfall of raid 0. loose one drive, loose all data
Old August 29, 2011, 05:23 PM
Thanks for reminding me of the weak point of raid 0. I found out I cannot get WD 640 black any more. I'll have to get a single 1.5TB drive and use this 640 for my older pc.
Old August 29, 2011, 05:50 PM
MARSTG's Avatar
if your existing HDD has been installed in RAID 0 config from the beginning, despite the fact that it is a single drive, there should be an option of the managing software to simply add another drive to the matrix without destroying the data. i think this is the Online Migration Option.
Old September 1, 2011, 06:47 PM
Thanks Marstg. My hdd was not installed in Raid 0 configuration. I will consider this option when I install my new drive.
raid 0 question tanin Storage 1 May 19, 2010 11:20 AM
Raid question Olorin Storage 12 January 26, 2010 12:09 AM
Question on Raid 1 Bojamijams Storage 13 October 3, 2009 12:23 PM
Question(s) about RAID, HDD's, and SSD'S AmuseMe Storage 28 September 6, 2009 10:22 AM
RAID question miggs78 Storage 17 August 30, 2008 03:12 AM
