I just picked up a Western Digital SATA 6Gb/sec 1TB Caviar Black (WD1002FAEX).
I used Acronis TI Home 2010 and cloned over windows 7 ultimate 64bit.
I am noticing that load speeds seem to be about 25% faster than before.
I tried to run the windows experience test but got an error accessing the disk performance.
The mobo is a Gigabyte MA770-UD3 ...
GIGABYTE - Motherboard - Socket AM2+ - GA-MA770-UD3 (rev. 2.1)
I tried a jumper but ended up putting in on 3-4 which as per the photo below is to enable PUIS but it would not boot so I removed it.
Should I put the jumper on 5-6 or just leave it without jumpers?
Since it is giving me faster load and boot times, should I consider doing something else to it like alignment?
WD Support / Downloads
My hdd is like the one in the photo but was manufactured last month ...
