Old August 22, 2011, 08:42 PM
Default Weird HDD problem
So my HDD says that it has 313gb of data via windows explorer, but upon backing up that whole drive it really only has 189gb of data per windirstat. http://img545.imageshack.us/img545/3830/wtfvs.png there is a picture.. What could be causing this?
Old August 22, 2011, 09:47 PM
supaflyx3's Avatar
Hidden files maybe, I'm not sure if windows explorer takes those in to account.
Old August 22, 2011, 10:31 PM
look up partitions,hidden or not
then use treesize
Old August 23, 2011, 03:17 PM
I second supaflyx3's suggestion that it's admin access. [Edit: This looks like the case because "System Volume Information" reads as size 0.] Did you run WinDirStat as admin?
The other possibility could be errors on your drive (i.e. run chkdsk and try again), or block sizes. Notice for small files that the "size" and "size on disk" are different?
I never checked which one of the two WinDirStat uses, but if you have a lot of little files (i.e. from doing work with programming), the difference can add up to be quite large.
Old August 23, 2011, 07:51 PM
ipaine's Avatar
Originally Posted by _dangtx_ View Post
then use treesize
I highly recommend Treesize. It can show you how much space is actually getting used and what is using it up. You can get a free version here: TreeSize Free - Quickly Scan Directory Sizes and Find Space Hogs
Or you can pay for the pro or personal versions.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Weird wifi problem clouter Troubleshooting 1 December 27, 2010 10:08 AM
Weird problem JerryZ CPU's and Motherboards 6 July 8, 2010 09:28 PM
Weird startup problem Haiden Troubleshooting 1 May 18, 2010 08:24 AM
Weird problem with Crysis! Need help!! esperasoppa Gaming 10 December 18, 2009 06:24 AM
Weird problem Kilauea Networking 16 August 21, 2008 09:35 AM
