Old August 12, 2011, 10:47 PM
TopDogZero's Avatar
Default Add in SATA 3 card
Hey guys I'm looking in to getting the Patriot Pyro 60GB SATA3 SSD, but I was wondering since my system is SATA2 should I get a PCI-e SATA3 controller card? Would the extra bandwidth make any difference in system responsiveness? I donít care too much about maximum throughput as I wonít be copying large files back and forth from the drive, itís just going to be for my OS and most used apps, also is there problems with booting from add in controller cards? Your comments would be appreciated.
Old August 13, 2011, 07:39 AM
TopDogZero's Avatar
This is the card I was looking at Syba (I/O Crest) SATA III 2 Internal 6Gbps Ports PCI-e Controller Card (SY-PEX40039) | Canada Computers
Old August 13, 2011, 09:15 AM
I wouldn't bother, I don't believe there's any benefit other then pure throughput.
Old August 13, 2011, 05:28 PM
TopDogZero's Avatar
Thanks for the reply.
Old August 13, 2011, 05:52 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
That card...like all others wont pass on TRIM. Take a look at the Corsair Perf 3 256 review and the non trim enviro testing. Now make the numbers worse as the 60s are slower than the 120s which are slower than the 240s...then make it slower again as the Pyro is a ONFi 1 based unit not ONFi 2.
SF gen 2s like SF gen 1 SSDs are a less than optimal choice for non trim enviro. Take the hit to performance and run it on the SATA 2 ports...or get a Intel 320 or other SATA 2 ssd. ;)
ďif your opponent has a conscience, then follow Gandhi. But if you enemy has no conscience, like Hitler, then follow Bonhoeffer.Ē - Dr. MLK jr
Old August 13, 2011, 06:45 PM
TopDogZero's Avatar
Thanks AKG I did not even think about it messing up TRIM, it’s an absolute no go for me then, I’ll just use onboard SATA2.
PCI-E sata expansion card bissa Storage 3 May 27, 2011 07:40 AM
Extra internal sata port - PCI-E card JMCD Storage 6 August 20, 2010 08:43 PM
ASRock P55 Bundles SATA III Card with Motherboard FiXT Press Releases & Tech News 2 August 18, 2009 10:31 AM
