Old July 28, 2011, 08:10 PM
Default Are SSD's with TRIM pretty much on autopilot?
Meaning, I don't have to do anything beyond what I would do to a normal hard drive?
(Besides not defragging?)
Old July 29, 2011, 08:35 AM
I run Debian linux on my OCZ Vertex 2 50 GB, and have the kernel that supports trim. I have tested it once and confirmed that trim is running.
Windows 7 has auto deflag on. Maybe you need to turn it off? I don't know since I do not use win7 on ssd.
Old July 29, 2011, 08:56 AM
lowfat's Avatar
As long as you are using the stock MS AHCI driver or the newest Intel or AMD driver then you shouldn't have to do anything else.
Old August 8, 2011, 07:19 AM
JimboToronto's Avatar
I'm not much of a Linux person, but I'm curious. If the kernel supports TRIM, does it also automatically align your partitions to the SSD's NAND blocks like Win7 or do they have to be manually aligned as with WinXP?
Just wondering thanks.
Old August 8, 2011, 08:07 AM
Caldezar's Avatar
OP, provided your SSD, OS and chipset support TRIM, then I believe you should be good. You can also run 'fsutil behavior query disabledeletenotify' from a command line in Windows to see if Windows is currently set for TRIM. ('0' means TRIM is enabled, '1' means it's not)
Old August 8, 2011, 09:49 AM
lowfat's Avatar
Windows 7 is always set for TRIM unless you disabled it for some reason.
Old August 8, 2011, 03:54 PM
I am wondering too. Before I installed it, I did not know anything about SSD. So, I bought this to experiment. I started out using a linux partition manager to divide the ssd into 3 partitions. Then I changed my mind, and changed it back to one single partition and installed Debian/squeeze on it. Squeeze does not TRIM, but I just need to run hdparm once in a while to clear the garbage. Also, I do not use it for data, just for the programs and packages. After 3 months, I upgraded Squeeze to Wheezy which has TRIM support. It has been working fine, and I did not bother to run benchmarks. So, I do not know what this partition alignment thing is and what effect it has if not aligned. Maybe the partition manager took care of it.
BTW, the OCZ support forum has a sticky on alignment, but my heads start to spin when I started to read it, so I decided to leave it alone since it is working well.
RAID SSD's TRIM/GC Questions bkh2 Storage 5 September 15, 2010 05:48 PM
SSD without TRIM Magnetic Storage 9 August 14, 2010 01:36 PM
Why You Need TRIM for your SSD [bit-tech] FiXT Storage 11 February 5, 2010 12:31 PM
Trim enabling and ssd toolbox issue BT! Storage 35 January 22, 2010 11:14 PM
Crucial Micron D9JNL - 6GB DDR3 1066 - pretty good and pretty cheap! zlojack RAM 15 April 30, 2009 05:46 AM
