Old July 27, 2011, 12:24 PM
Default Need help finding a SSD with a 7mm height
First off new to the forums, read it every now and then. But this time I need some help.
So hey everyone!
Ok so, I have a Lenovo e420s, and the Notebook will only accept drives with a 7mm height. I am having a really hard time finding a drive that will fit this spec. ( I also have a friend with a Thinkpad X1 w/ the same issue)
I am looking for something in the 128GB range ,So far these are the to models I can find that exist on paper.
Micron SSD - MTFDDAK128MAM-1J1 (can only find bulk prices and seems a little high in price)
Intel SSD - SSDSA2BW120G301 (I cannot find this part in stock in any store)
If anyone has any information or recommendations it would be greatly appreciated. There seems to be ways to modify some of the drives but I am trying not to void any warranties on the drive.
Old July 27, 2011, 02:01 PM
supaflyx3's Avatar
X-25M, X-25V etc, all the intel SSDs with the plastic bevel, can be removed and are now 7mm thick.
I think the 1.8 inch ssd will fit, but you need to check the dimensions to make sure. I am watching for the price drop of the Kingston SSDNOW V+ 180 for my Sony TT laptop. I know it fits because some users have put it into their Sony TT laptop.
Newegg.ca - Computer Hardware, Hard Drives, SSD, SSD,1.8
The 2.5 inch ssd's have a regular sata connector and 5v power, while the 1.8 inch have micro-sata connector which has 3.3v. You need to make sure which connector you have in Lenovo.
Old July 27, 2011, 04:57 PM
Trial Member
Default I also need help with this
Is it smarter to wait? Do you forsee these disks becoming the 'norm' or is my 'no compromise' Lenovo x1 actually going to have to compromise?
Old July 27, 2011, 10:03 PM
The Drive currently in my system is a 2.5" 250GB Hitachi 7mm thick drive, I believe that this uses the standard 2.5" Sata connectors. As for removing the spacer on the Intel drives, I hear that this will void the warranty and that you will require shorter screws for the drive if you do remove it.
Any insights, I really don't want to void the warranty in light of all the issues I've seen people have with SSDs in general.
Old July 28, 2011, 04:31 AM
ipaine's Avatar
We ran into this at work with a Lenovo. The only SSD's I could find that would fit were the Intels and only the X-25 series, not the newer 320 or 510. Needless to say this has caused Lenovo to lose serious points with me on whether or not I recommend them to people at work.
So from my understanding you are pretty much stuck with the older Intels. At least from any I could find.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Old July 28, 2011, 07:40 AM
supaflyx3's Avatar
That plastic bracket is put on the SSD for that exact reason, so it'll fit in 7mm enclosers. It won't void your warranty.
Old July 28, 2011, 07:32 PM
Thanks for all the input, I ended up getting a Intel 320 120GB Drive, removed the spacer put some new screws in and it fit like a glove :)
Tags
ssd 7mm lenovo
Front height channels and sound cards? Lyxtwing Audio 15 September 22, 2010 11:18 PM
Half height 140mm fans? Fudd Rucker Water Cooling 11 January 12, 2010 05:50 PM
Seagate Looks to Roll Out 7mm 2.5in Hard Drive FiXT Press Releases & Tech News 0 December 8, 2009 01:27 PM
i need help finding a program EaGle1337 Off Topic 0 January 26, 2009 06:37 PM
Need some help finding those ebdoradz Off Topic 0 March 17, 2008 07:42 AM
