Old July 17, 2011, 03:35 PM
Your_friendly_gamer's Avatar
Default corair f60 sata2. first time using a ssd, need help
Hi all,
I picked up this drive to comiment my new set up. I have never owned or used a ssd before. I installed windows on it and it works great. However it only has 60 gig capacity meaning I cannt install more than 2 games at a time. I tried using my raptor 150 gig drive as a secondary drive and tried installing the games on it. It worked, however when I try ro play a game, the game runs super slowly or just freezes everything. However when I install the same game for example dirt 3, I have no problems. Is there somrthing I need in bios or something to make this work?
Here is my setup:
Ga-Z68x-Ud5-B3
I7 2600K clocked to 4.5 ghz
Cp 850 watts psu.
Let me know please I'd really appreciate it.
Thanks!
Old July 17, 2011, 04:22 PM
supaflyx3's Avatar
Did you install drivers?
Old July 17, 2011, 04:33 PM
Yess off gigabyte's site
Old July 17, 2011, 05:33 PM
Not sure I understand what the problem you're having...you're having trouble playing games that are on your raptor but it installs fine right?
It might be that your hard drive is dying, try running HDTune and check it's health / scan for errors.
Old July 17, 2011, 06:00 PM
Yea I don't think the raptor is the issue, I just tried installing the game on my other hard drive, which is a wd black tb 7200 rpm and same issue. The games install fine but just wont run from the 2ndary drives. I can only run games for some reason dirctly from ssd and thats all. :(
Old July 18, 2011, 05:28 PM
I have 2 of these in RAID0 as my C drive. This setup enables me to store more games, and doubles the read speed and write speed. Make sure you use AMD RAIDXpert to enable NCQ.
Old July 18, 2011, 05:33 PM
Before I got my second F60 for the RAID0 setup, I used to install some games on my D drive (which is a regular Hitachi hard drive). The games ran well, just didn't load as fast as the games installed on the SSD.
mechanical vs ssd : the test of time! _dangtx_ Storage 6 April 12, 2011 12:59 PM
Corsair F60 or Vertex 2 60GB Modus Storage 6 September 28, 2010 02:34 PM
SSD sata2 & sata3 mobo Dan Storage 3 April 16, 2010 01:03 PM
it's time for a SSD MarkOne Storage 26 December 25, 2009 01:47 PM
