<~----> Best bang for the buck 120gb or 128gb ssd - Hardware Canucks
Old July 1, 2011, 03:09 AM
bigFOIG's Avatar
Default Best bang for the buck 120gb or 128gb ssd
I'm thinking about getting my first SSD and I need some help. Does anyone have recommendations on which 120gb or 128gb ssd to get? Or which ones I should avoid. It must be SATA III, and hopefully around 200 bucks. Thanks.
Old July 1, 2011, 07:41 AM
If you go to my thread below:
Which SSD to get?!?
I pretty much asked the same question. I've done a bunch of research and reading and AKG's advice is solid. Intel's 510, Crucial M4, and Corsair Performance 3 are all SATA III. I'm going to throw OCZ's Vertex 3 in the mix even though I was a bit weary about it with its mixed reviews but if you read the reviews for the other listed brands (on newegg.ca), everyone of them seem to have at least one instance of a drive dying. Seems OCZ just got hit the hardest with poor customer service.
I'd rule out Crucial M4 because it doesn't include 3.5' bracket to mount inside a desktop, so that will be an additional cost. Intel and Corsair have generally the same price range (both have MiR). It seems the cheapest right out of the gate is the Vertex 3 on newegg.ca @ 269.99 no rebate.
Its a toss up for me, but if you're not looking to spend more than 200, you may have to reduce your SSD size or go down to SATA II?
That's my two cents at least
Old July 1, 2011, 10:08 AM
lowfat's Avatar
OCZ Vertex 2 E Series 2.5in SATA II Solid State Drive, 120GB at Memory Express Computers if you don't mind an MIR.
Sure it isn't SATA 6Gbps. But the difference in noticeable performance between it and newer drives is going to be extremely small.
Old July 1, 2011, 12:08 PM
JD JD is offline
I'd probably get this: NCIX.com - Buy Corsair Force 3 Series 120GB 2.5IN SATA3 6GB/S Solid State Disk Flash Drive SSD Sandforce SF-2200 - Corsair - CSSD-F120GB3-BK - in Canada
Assuming you can grab it for $200 before the sale runs out of stock.
Old July 2, 2011, 10:07 AM
OCZ Vertex 3 120gig on sale now till Monday 199 with MiR!. I picked myself up one.
NCIX.com - Buy OCZ Vertex 3 120GB 2.5IN SATA3 6Gbps Sandforce SF-2281 Solid State Disk Flash Drive SSD - OCZ Technology - VTX3-25SAT3-120G - in Canada
Old July 2, 2011, 12:16 PM
Caldezar's Avatar
Originally Posted by JD View Post
Is the Force Series 3 still having firmware troubles with the drives failing after an hour of use though?
Old July 2, 2011, 03:48 PM
EmptyMellon's Avatar
Nope. Corsair did their recall; so in theory, all the new Force 3s should be problem free. Though now they are comming out with Force 3 GT, so that should improve the mix. Hopefully AkG will be doing a review soon - compairing the two.
Old July 5, 2011, 12:37 AM
bigFOIG's Avatar
Originally Posted by ad5ter View Post
Just picked one up from memoryexpress. I priced matched with NCIX and the sales representative told me that the MIR was NCIX exclusive, so he will just sell me the drive for 199.99, instead of 229.99. And then after I bought it, the manager came over and told the sales guy that the MIR is actually not NCIX exclusive, and the MIR will actually be accepted from MemoryExpress purchases as well.
Long story short, I got a 120GB Vertex 3 for $170 plus tax! Woooooooo!
Old July 5, 2011, 09:02 AM
Haha..gratz
1st - ASUS P8P67 Deluxe, i7-2600K o/c 4.6Ghz, Corsair Vengeance DDR3-1600 16Gig, 2x HIS Radeon 6970 CF, Custom WC from Dazmode, Corsair AX1200, Corsair P3-128 SSD, Coolermaster HAF-X
2nd - ASUS P5B Deluxe/WiFi-AP, Q6600 o/c 3.6Ghz, Corsair Dominator 6Gig, Sapphire 5870V2, Swiftech H20-220 Ultima XT, Corsair AX850, Antec 900
Old July 5, 2011, 09:24 AM
lowfat's Avatar
Wowza!
Best Bang-for-Buck SSD (120GB or under) right now BigHurt88 Storage 7 November 22, 2010 10:43 AM
Best bang for the buck dante1 Video Cards 15 December 31, 2009 10:10 AM
bang for buck ssd's gingerbee Storage 5 December 7, 2009 07:54 PM
Best bang for buck? ImAPC Video Cards 5 September 18, 2009 02:31 PM
Bang for the buck g10 New Builds 8 August 13, 2008 11:19 AM
