Old June 20, 2011, 10:22 AM
Default 5K3000 2TB or WD20EARS 2TB?
NCIX.com - Buy Hitachi Deskstar 5K3000 2TB SATA3 32MB Cache 3.5IN Internal Hard Drive OEM - Hitachi - 0F12117 - in Canada
NCIX.com - Buy Western Digital WD20EARS Caviar Green 2TB SATA2 3Gbps 64MB Cache 3.5IN Hard Drive OEM - Western Digital WD - WD20EARS - in Canada
I need a 2TB storage drive, I read alot of customer reviews on both drives that seem to say it's a hit and miss if you get a good drive.
My mobo is sata2 and the 5k3000 says sata3 is it backwards compatable on a sata2 header?
What is this "park" thing with WD?
Both drives are $70, which would be the better of the 2?
Getting completly lost on what drive to pick.
Thank you.
Gaming FX 8350 stock / Tuniq Tower 120/ MSI GTX 1070 Armor / G Skill 32GB / S12D 850w/ GA 990FXA-UD3 /SSD 240GB , WD1TB FALS, 3TB Toshiba / Dell IPS 1920x1080/ Win 10 64
Daily Use x4 965BE 3.6GHZ/GA 970 Gaming/ R7 265 1GB /EA750w/4x4GB ram/Win 10 64 and 24TB of hdds
Old June 20, 2011, 10:24 AM
I will NEVER EVER buy a Hitatchi drive ever.
And the WD is far better and the issue with the Greens is they go to sleep ever 7 seconds but you can change that easily enough.
Old June 20, 2011, 10:43 AM
I don't mind either drive.
Usually SATA2 is cheaper. it doesn't matter what you get, but SATA3 is generally useless for mechanical drives
Quiet 2TB Raid 1 ??Wd20EARS??? dustin1706 Storage 10 July 8, 2010 03:12 PM
