Old May 25, 2011, 12:31 PM
Default What's the Maximum Read/Write of SATA II (3Gb/s)?
Hi Guys,
I'm just curious as to whats the maximum read/write capability of SATAII (3GB/s)? I'm asking because I bought a SATA6GB/s SSD and would like to know what speeds I should expect with SATAII?
Old May 25, 2011, 08:03 PM
Mook06's Avatar
3gbs = 375MBs
so 375MB/s theoretical maximum, maybe reduce 15% for overhead, around 300MB/s
Old May 29, 2011, 04:44 PM
Maximum speed is 3Gb/s /(10B/b)=300MB/s. Remember, the encoding scheme that SATA uses has 10bit bytes (essentially).
Old May 29, 2011, 08:55 PM
Real life tests with SSDs seems to get around 285MB/s for the SATA 2. I guess SATA 3 would be useful for a RAID with cards using the Port Multiplier function although even that would be kinda complicated and overpriced given the thing you can get that Supermicro card that doubles as SAS/SATA RAID adapter for less than 100$, I mean the AOC-SASLP-MV.
slow SSD read/write speeds OuTR Troubleshooting 10 July 28, 2010 06:33 AM
USB 3.0 Enclosure with Sata, limited to 3gb/s or 5gb/s? Proto Storage 1 March 13, 2010 07:25 AM
