-   -   hp ml150 drive mounting (http://www.hardwarecanucks.com/forum/storage/4338-hp-ml150-drive-mounting.html)
badbob233 January 29, 2008 11:59 AM
I picked up an hp ml150 g3 5120 smartbuy server which included an sas hot plug drive bay, but no drives. I have a failing server from which i would like to transfer the raid card and ide drives. However, I'm having trouble finding a part number for drive rails. I've already removed the backpane, so cabling won't be an issue. any suggestions?
Cptn Vortex January 29, 2008 12:41 PM
Ouch, that is a pain. The drive rails are NOT an aftermarket part. Essentially, you are going to be stuck with buying HP harddrives, which I may add are exptremely overpriced. I've run into this problem before, and HP was less than helpful, let me tell you.
