Old May 13, 2011, 04:27 PM
Blu's Avatar
Blu Blu is offline
Default How does more then 2.2TB work on XP?
I was just getting ready to set up my 4 bay raid enclosure to use raid 5 on it, but I was wonder how do I go about using it on a XP pc when the max HD size is 2.2TB I believe and this raid 5 setup will be 6TB? How do I go about this, thanks.
Old May 13, 2011, 04:31 PM
Not gonna happen unless you go to XP x64 to allow GPT tables.
Old May 13, 2011, 05:08 PM
Blu's Avatar
Blu Blu is offline
Same thing with vista/7 as well?
Old May 13, 2011, 05:21 PM
Sorry I just realized what you were asking.
to answer, it doesn't matter. you can use any windows to network the RAID.
Old May 13, 2011, 05:24 PM
Yes. GPT tables are the only way to use 2TB or more hard drives.
Old May 13, 2011, 05:27 PM
uhh wait. The RAID enclosure is 6 TB, not a single hard drive.
it doesn't matter, the enclosure probably can't support more then 2.2 TB anyways. (I'm assuming a 3 x 2TB setup?) it's still accessible from Windows
Old May 13, 2011, 05:56 PM
Blu's Avatar
Blu Blu is offline
It's 4x2TB and can run in JBOD or raid5 I was going to do raid 5 but might just jbod it.
Old May 13, 2011, 06:09 PM
right right 4x2 will yield about 5.2 TB, but either way it doesn't matter, it's all accessible in 32 bit windows.
Old May 13, 2011, 10:55 PM
Blu's Avatar
Blu Blu is offline
as enaberif don't I need the 64 bit to have GPT Tables to get this to work?
Old May 13, 2011, 11:44 PM
nope, only if the drives were directly connected, a network drive will work beyond 2.2 TB in 32 bit (the host would obviously need to be 64 bit for 2.2+ TB drives to work)
besides, 32 bit can address DRIVES that are less the 2.2 TB , which 2 TB drives are. it doesn't matter if you're RAIDing or JBODing them, they're still under 2 TB.
GIGABYTE Announces 3TB+ Unlock Utility FiXT Press Releases & Tech News 3 March 30, 2011 02:46 PM
Seagate Ships 3TB Desktop Drives FiXT Press Releases & Tech News 8 March 1, 2011 08:35 PM
tweaktown : wd 3tb green drive _dangtx_ Reviews & Articles from the Web 0 October 21, 2010 12:49 AM
TDK Plans Its Route to 3TB Drives and Beyond Soultribunal Press Releases & Tech News 0 February 9, 2010 09:39 AM
