Old May 13, 2011, 03:00 PM
Delavan's Avatar
Default AKG and all, superfetch, SSDs, BSODs
Howdy AKG, resident SSD guru and other fellows,
I've been having issues and I want to share info, double-checking with you all also.
My steps:
1-Buying my Sandy parts
2-system building
3-OS install (Win7 64) on my goldie oldie VERTEX 1 FW 1.5 health 86% (never had issues with it, 18 months old...)
4- config a few things in BIOS
5-REBOOT and run SSDTWEAKS
I guess it disables superfetch...
I've been getting BSODs...always the MEMORY MANAGEMENT one....
I reserched, DLed MEMTEST 86+, ran it...got no errors...
I tried a lot of things...then I found that the SUPERFETCH setting (located into MEMORY MANAGEMENT in regedit) was disabled,
I re-enabled superfetch...could it be the cause of my errors??
anybody relates to that situation?
i7 4770K @ 4.0GHz / Corsair H100i / MSI Z97A Gaming 6 / 16GB Kingston Hyper X 1.5V 1600 / MSI GTX1070 FE / Samsung 850 Evo 500gb / Corsair Performance Pro 128GB SSD / Intel 520 120GB SSD / WD Black 640 GB storage / XFX 850 watts Black Edition PSU
Old May 13, 2011, 03:06 PM
if you drop in another drive and nothing else changes, and its fine? perhaps.
Old May 13, 2011, 03:21 PM
Delavan's Avatar
DAN, you're killing me...lol
if you fork more cash for another drive and feel like re-installing OS, software and games, and its fine? perhaps.
I'm not there yet. My SSD was running fine on my P5Q pro...now on P8P67 Deluxe...
Old May 13, 2011, 03:32 PM
dude all im saying is try another drive...maybe cable...and so on.
yes settings can bork something out,or sometimes the two just dun git along,
but if you swap dementially,youll probably find it.
i just spent 3 hours trying to get something similar sorted,got tired went to the store got another
model and all is good...:)
Old May 13, 2011, 04:13 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
I have had a LOT of bad luck with the various ssd tweaks progies. BSOD is a common issue. Prolly screwed something up. Nuke it, start from scratch and then do the tweaks MANUALLY. See if it BSODs. if it does. try with a hdd and see if its the storage or mem or etc etc.
Old May 13, 2011, 08:52 PM
Delavan's Avatar
Thank you both for your answers.
It is possible that the SSD TWEAKER caused the issue then...if I keep getting BSOD /memory management, I will have to re-install. I got it.
Sad but true.
now, I'll be crossing fingers and hope for the best...
Old June 19, 2011, 11:02 AM
Delavan's Avatar
As an update, for anybody who cares, I re-installed Win& 64 last night...
No "memory management" blue screens, and I've been able to install ALL updates this time...
The only SSD tweak I made was to disable hibernating....I haven't used any "automated SSD tweaking software) this time around.
now, the 'ol Vertex 1-120GB is still working fine......guess I got a good one!!!
Old June 19, 2011, 11:58 AM
MARSTG's Avatar
I got a Vertex and Vertex Turbo and had no issues installing and keeping W7U64 doing all the tweaks manually. so maybe that is the best way
Old June 19, 2011, 12:43 PM
Shadowmeph's Avatar
thats what I was thinking, some of the so called tweaks are just common tweaks that can be done with any hard drive and some of them you don't really need becasue now days the systems are allot faster then those old tweaks . hell allot of those tweaks I used to use on my old P4 system so I can get better fps when playing in a gaming tournament
Old June 19, 2011, 12:55 PM
Delavan's Avatar
Yes. The thing is: I had the same SSD on the older P5Q Pro socket 775 no issues after a fresh install/w SSD tweaker.
With the Sandy/ P8P67 Deluxe, with the same SSD and the same tweaker, I got issues.
so yes, I will always use the "manual" tweaks from now on!!!
BSODs on Startup - RAM or Motherboard Issue? PeopleCanFly Troubleshooting 9 December 12, 2010 07:05 AM
Need Help with SSDs! revixd Storage 21 January 11, 2010 04:45 PM
Random BSoDs, cannot nail down reason. Fenrise Troubleshooting 8 September 7, 2009 06:20 AM
Random BSODs on Prime stable system. Realityshift Troubleshooting 17 March 17, 2009 10:13 PM
Some strange BSODs zlojack Troubleshooting 11 September 24, 2008 11:28 AM
