If you dont already have it...dl the latest OCZ toolbox here at the bottom of page 1
Guide New update on the 64Gb IC OCZ SSD drives
At this point in time there isnt much you really can do. 25nm is here to stay.
To make sure you are getting ALL the speed you can...do a sani erase on it (also avail in OCZ toolbox...and the real reason you should DL it), then a quick format (in a TRIM capable system) that will nuke all the data, do an end run around the Durawrite tech and get your cells into a virgin state. Then run AS-SSD again....if the numbers dont improve. You are SOL. Assuming both SSDs are in the same rig that is. If not, maybe the other rig just doesnt like your ssd. Yank it and stick it in the same rig. run as-ssd see if the numbers improve. TBH, this is bascially the reason I dont buy SF first gen 25nm drives. I either get 3x or Sf gen 2s...or C300s or M4s. 25nm + SF gen 1 == fail.
