Old May 2, 2011, 05:36 PM
Default No IDE cable?
Bought a whole PC build, but theres no IDE cable that would go from the DVD drive to the motherboard... Is it missing or am I just dumb?
Old May 2, 2011, 05:39 PM
FlyingFish's Avatar
Where did you get it from? Does the drive use SATA cables instead? It's a thinner cable that looks liek this:
Old May 2, 2011, 05:49 PM
Yeah it does have SATA cables but most tutorials showed both SATA and IDE cables plugged in
Old May 2, 2011, 06:05 PM
CTA's Avatar
CTA CTA is offline
usually mobo come with one slot of ide... but if your mobo didnt have one then you are out of lucky...
btw... did you check slot of dvd-rw... newer one usually have sata slot...
NEW: customize case, hx100, i7 920, supreme hf, x58 sabertooth, 3gbx2 ram of ripjaws, xfx hd6950 CF. vertex 2 60gb, seagate and hitachi 1tb, dual mcp355 with ek rex v2, 2x koolance ar697, 2x mcr320, 6x zm-f3 fans.
OLD: cm 690, hx620, intel q9450, True Black, ga-ep45-ud3p, 2gbx2 ram of mushkin xp2 8500, xfx 285. wd caviar se16 640gb, 4x zm-f3 fans.
Old May 2, 2011, 10:31 PM
dustin1706's Avatar
IDE is becoming obsolete. like CTA says, does your mobo even have an IDE port?
Rig1 in "My System Specs"
Rig2: Q6600, P5DN-D, GTX650, 4GB HyperX, LG BD drive, TT armor case, ek supreme HF, 655 pump, XP
Dell XPS17 - i7 2820QM, 8GB ram, 1920x1080, BluRay, GT555m 3GB, 240gb Neutron GTX, 640GB Seagate, Win7 64
Server - i5 3450, Asus P8Z77-I Deluxe, 4GB DDR3, LSI MegaRAID 9240-8I, OCZ Vertex 4 120GB, 2x SG Barracuda 3TB(RAID1), 2x WD green 2TB(RAID1), Fractal Design Array R2, WHS 2011
Old May 2, 2011, 10:41 PM
ZZLEE's Avatar
Ide to stata costs 7 to 15 $ new drive 20 $ :)
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old May 2, 2011, 10:58 PM
IDE isn't becoming obsolete, it is obsolete.
The majority of new motherboards won't have IDE, only a select few have them for people who wish to have support for legacy devices.
SATA is used for new drives.
TRIM in IDE rapmaster Troubleshooting 3 May 5, 2010 05:56 PM
Large IDE HD Sui Storage 4 February 13, 2010 10:22 AM
[FS] Xbox 360: Halo 3 ODST, HDMI AV Cable, VGA AV Cable (All Brand New) icarus2 Buy/Sell & Trade 1 December 20, 2009 11:30 AM
USB 2.0 TO SATA IDE CABLE does not work properly zillah Storage 21 May 18, 2009 09:54 PM
SATA to IDE.... chibi_man Troubleshooting 9 October 20, 2007 11:02 AM
